Fuel from rear tank only
Hello, I have an 84 F150 with dual tanks and I believe am only drawing fuel from the rear tank at this time. Both tanks and gauges worked fine when I purchased the truck last winter. A few weeks ago I filled up the tanks and set the switch to the front tank. I drove about a hundred miles and the gauge didn't go down at all. I stopped at a gas station and I flipped the switch to the rear tank and the fuel gauge showed a drop in fuel level. This lead me to believe that fuel was only coming from the rear tank regardless of the switches position. The front tank was still full and the rear tank had gone down (I checked this by filling up at the station). Should I check the fuel pumps or the fuel tank selector valve first?
I don't know what you have, but if your truck is original, you only have one fuel pump. You have a solenoid valve mounted on the frame rail about midway on the driver's side that switches the lines from the front tank to the rear. That's where I would start troubleshooting.
I believe everything is original. I will check out the valve then. What is the best way to troubleshoot the valve.
Put a testlight on the wire and see if you are getting voltage or not when the switch is switched from front to rear. If the voltage switches, then I would suspect the valve itself.
Also... check the fuse that controls the tank switch.
Looks like the gauges are working for now. I will check the tank levels when I fill up next time. The real cold temps we have here in WI have a habit of making things run haywire sometimes.
Can I presume the diagnostics will be the same for my 94 F250 Diesel? I have same issues however the Gauge does not show level for the front tank.
Originally Posted by rwelli1001
(Post 13878877)
But the wiring changed in 1987 (or so) and the switching valves changed in, um, I think it was by the early 1990s. So, the specific tests we do here may not at all tell the truth on something as modern as a 1994. Do an Advanced Search, search only the 1987-1996 forum, look for posts authored by subford, enter in your favorite search criteria, sort the results based on relevancy, and see what ya can find in their archives... might even have this listed in their Sticky, I don't know for certain.... |
Originally Posted by tkisling
(Post 13878234)
(Post 13878877)
Frankin, I should have been a little more clear. What I meant is that the gauge is steadily going down for the front tank now, so the level in the front tank is falling and the valve is working properly. Hopefully it stays this way.
