1993 f350 injectors info needed
Hi friends
I have a 1993 f350 idi turbo with 120k on it. just replace ip a few weeks ago. It was leaking, went on fine and working good so far. but i have notice that i have white smoke at start up. starts right up no problem and when driving it smokes when i get on it (white smoke only engine is warm). it also smells bad at idle exhaust smell but no smoke just bad exhaust? question im asking is it time for new injectors or is this normal? thank you :-X22 injectors are OG |
Injectors and injection pump are generally replaced at the same time because they both have the same life expectancy. Sounds to me like you need new injectors, and to get your new injection pump timed properly. Good luck! :)
Thanks Lindstromjd
Will replace injectors and look up how to adjust timing on ip and report back. Thanks again |
