drptop70ss |
12-07-2013 10:52 AM |
I always defer to OEM since that is where the money is spent on development. What did the 70 mustang use? GM normally used 5/16" for lower HP engines and 3/8" for the higher HP engines. For example a 200HP engine would get the 5/16" but the 250HP would get the 3/8"..but then it depends on how you plan on using the truck. A higher HP engine putting around doesnt need much fuel.
I converted lower HP cars to 396CI/325+HP engines with the original 5/16" fuel line and ran to 6000RPM with no issues, so it will depend on how much fuel your particular engine needs and how you run it.
