85 F150 won't start
well i have a question i have a 1985 ford f-150 with a 5.8l HO 4V motor i lost the timing set an replaced it an i have spark compresion an im priming the carb with fuel an it wont hit off an it has new fuel line pump an filter a new timing set an cap rotor coil an ignition moduale can anyone give me a reason it shouldnt start if the firing order is right
I didn't see this Ben.
(thinking once these threads got moved, notifications were broken.) If you have the three essentials; fuel, spark and compression- the engine should show at least some sign of life. Can you tell us some more about what it is or isn't doing? |
Moved to proper forum
Thanks Chris! :)
What do you mean by "lost the timing set"?? Did you replace the timing chain and gear set? If so, it should be dot to dot on the sprockets.
