1962 F100 Restomod
I have just started working a project that really means alot to me. It is a 1962 F100 Uni-body pick up. I use to have a 61 that my stepfather gave me a long time ago. When my stepfather passed away my mother ended up moving.The truck had gotten left behind and then disappeared. My brother gave me this 62 in place of it so I am building it in memory of my stepfather.
https://www.ford-trucks.com/user_gal...id=256590&.jpghttps://www.ford-trucks.com/user_gal...id=256593&.jpghttps://www.ford-trucks.com/user_gal...id=256619&.jpghttps://www.ford-trucks.com/user_gal...id=256592&.jpghttps://www.ford-trucks.com/user_gal...id=256591&.jpghttps://www.ford-trucks.com/user_gal...id=256594&.jpghttps://www.ford-trucks.com/user_gal...id=256607&.jpg |
Good luck! What are your plans for her? I bought my first one in 86 because l had a good friend that had one. He died and a few weeks later l was at the salvage yard and there was one just like his. I have had it ever since. Another year or so and mine should be back on the road.
So far I am planning a Crown Vic front end swap, boxing in the frame for strength, and doing a frame off. I am still working out what engine I want to run in it.
I see the F O R D is in the center of the grill. Would that make it a 61?
I noticed that when my brother gave it to me and he swears it's a 62. It has been wreaked in the front so I'm thinking someone put a 61 grill and upper piece in it.
Here is a pic of the VIN plate if someone knows how to make sure for me. https://www.ford-trucks.com/user_gal...id=256632&.jpg
Vin is camera washed
The first three look like 154 Which makes it a march of 1960 production. 150,000 to 159,999 Its a 61. The plate is a 61 or 62 plate by use of the serial number above the VIN. Later 63 up plates removed this nomenclature to say "Warranty Number" Garbz |
Thanks, I guess I should change the name of this thread.
I started dis-assembly last weekend. I got the front end off and found a lot more sure holes than I thought.
https://www.ford-trucks.com/user_gal...id=256609&.jpgThe jnuts on the fenders were broken so I had to cut holes in them just to get them off. https://www.ford-trucks.com/user_gal...id=256610&.jpghttps://www.ford-trucks.com/user_gal...id=256608&.jpghttps://www.ford-trucks.com/user_gal...id=256596&.jpghttps://www.ford-trucks.com/user_gal...id=256603&.jpghttps://www.ford-trucks.com/user_gal...id=256600&.jpgThis is the amount of bondo I found in the passenger side fender. https://www.ford-trucks.com/user_gal...id=256617&.jpghttps://www.ford-trucks.com/user_gal...id=256604&.jpghttps://www.ford-trucks.com/user_gal...id=256605&.jpghttps://www.ford-trucks.com/user_gal...id=256614&.jpghttps://www.ford-trucks.com/user_gal...id=256620&.jpg |
Well I got more work done of it yesterday. It's a little cold out there today so I'm going to do more research of parts that I know I need so far. Here are a few pics of what I got done yesterday.
I took the seat, fuel tank, and mats out and this is what I found. https://www.ford-trucks.com/user_gal...id=256656&.jpg https://www.ford-trucks.com/user_gal...id=256657&.jpg https://www.ford-trucks.com/user_gal...id=256658&.jpg The steering column was kind of fun to take out but I got it. https://www.ford-trucks.com/user_gal...id=256691&.jpg https://www.ford-trucks.com/user_gal...id=256692&.jpg I know they make the two floorboad panels but does anyone know if anyone makes the lower firewall panel? |
Well I have figured out what engine I am putting in this thing and how I want to build it.
460 block Stock crankshaft ARP 350-6802 - ARP Crank Pulley Bolts ARP 150-2501 - ARP Balancer Bolt Kits ARP 255-5502 - ARP Main Stud Kits Eagle H-Beam Connecting Rods 6605F3D Milodon 31929 - Milodon Street and Strip Oil Pan Kits Milodon Stainless Steel Oil Dipsticks 22035 Ford Racing M-6600-A460 - Ford Racing High-Volume Oil Pumps Keith Black/KB Pistons KB137KTM-30 - Keith Black KB Performance Piston and Ring Kits Valve train D0VE heads with larger valves, port job, chambers polished and port match (330-ish/190-ish cfm flow @.600) Intake valve size increased to 2.19 Exhaust valve size increased to 1.76 COMP Cams Xtreme Energy Cam and Lifter Kits K34-247-4 COMP Cams High Energy Die-Cast Aluminum Rocker Arms 17045-16 Lunati Pro Series Stud Girdles 91647 Crane Rocker Arm Guideplate Conversion Kits 52655-16 Air/Fuel Weiand Stealth Intake Manifolds 8012 FAST EZ-EFI Self-Tuning Fuel Injection Systems 30227-KIT |
