Take your turbo to the limit with the Batmo Wheel Turbo Compressor wheel!
The BatMoWheel is a drop-in replacement compressor wheel for your stock turbocharger by Bullseye Power. Its unique design increases spool-up, throttle response and also increases power and efficiency. Bullseye Power has stepped it up again by releasing the exclusive "staggered" blade design now increasing flow rates by as much as 10% over the regular BatMoWheel. Available now in size ranging from 62mm to 83mm. If you want to push your turbo to the limit use, Triple Compression Technology!
http://www.thoroughbreddiesel.com/pe...batmowheel.jpg Check it out now! Batmowheel compressor wheel |
