Kalahari Willem 6.0 no starts
Hallo Everybody! I am writing from Maun in the Okavango Delta-Botswana. I run a safari outfit here. I have a fleet of old IH 1310 4x4's. But recently imported from the USA 2x F350's with V8 6ltr. The 2005 King ranch with 80 000 miles has been giving me an hard time. I dont have any of diagnostic kit, but the vehicle shows no check engine light....thanks to the forum i managed to get it running again but not perfectly:
1. Clutch switch caused no start, cleaned fitted back and started. 2. vehicle parked for 3 weeks, on start-up smoked like a train...no power, pulled and cleaned EGR, now running fine, but misfires it seems. 3. I replaced all filters. 4.Removed dieseltank and inspected fuel pickup and return line. 5. Did bubble check on injectors all fine. 6. Vehicle cranks 5sec + to start and it seems to start on a cylinder at a time. 7. Tested FICM and voltages all good in different modes. 8. Cleaned all sensors i could find. 9. Truck has power, accelerates fine, but just seems to miss at all revs. 10. sometimes idle perfectly and then engine shakes a little like misfiring on 1 cylinder. Any idea anyone? Greetings from the African Bush. Today it is 108F! |
moved to the 6.0 forum for better assistance
Originally Posted by pendukasafaris
(Post 13679044)
Thanks will look into that, the hardest thing is to get spares out here, the freight cost more than the parts!
Is it possible you are getting contaminated fuel? If you are that far out, maybe the quality of the fuel you are getting is not so good? ie water, not filtered well etc...Did you open up the HFCM and drain it? What does it look like? Have you replaced your fuel filters recently?
Hi Bill
The fuel appears clean, changed filters and found about 2 drops of water in the water trap, what baffled me was that the truck ran 3000miles without a problem, but i had it standing for 3 weeks while i was on safari, when i returned it started, cleaning the egr got it running again, i thought straight away dirty fuel after the long rest but filter were not dirty, although i replaced them. I inspected the wiring all over...we have some ambitious rodents here, but couldnt find anything. rgds Willem |
Could be an injector issue. You need a diagnostic tool that will tell you live data.
(Post 13679148)
Hi Bill
yes only 2 drops of water!
(Post 13679190)
(Post 13679190)
Since you removed the fuel tank and inspected the lines, I am assuming that you drained all the fuel from it at that time? If so, I see how that can rule out "old fuel" at least.
You really do need a code reader and a scan tool, but since you have two 6.0L's, you can swap parts from the working one to test a few components like the EGR valve and the FICM. Even with good voltages, the FICM can be bad. Also, sometimes the EGR valve is bad and simple cleanings do not work. That being said, your symptoms sure sound like a bad injector and that will be found with the test equipment. An AutoEnginuity would be best, but some others would probably give better advice than me on "which update AE runs on what computer software". The advantage of the AE over the scangaugeII is fairly significant. AE offers the ability to check injectors. Since you are in such a remote area, some spare parts would be wise IMO. Also, a fuel pressure gauge is VERY important and it would be wise to install one ASAP. ` If you catch low fuel pressure quickly, it isn't nearly as damaging to injectors. |
Thanks i will have a look at the gauges and scan tools. Another thing, i changed the alternator on this vehicle, the battery light kept coming on, if i played with the pigtail on the alternator it would charge but go off when you release it. fitted a new alternator and it work well for a while, but now it also starts to light up the battery light. is it usual for these alternators to get so hot? Like to the touch? i noticed on both vehicles, i understand they have high output but never experienced it before with other vehicles?
(Post 13679409)
(Post 13679409)
