2001 SD wheels
I have a 2001 F350 SD Dually and need to find a spare. I have the 5 spoke aluminum wheels on the truck itself. Was the original spare steel or aluminum? Where is a good place to start looking? I called some junk yards around here and none to be found. Thought I would ask before calling any more. I think the same wheel fits 1999 to 2004.
Thanks in advance for any ideas! |
Nobody? I think the problem is the old wheels used the 6.5 inch pattern and these use the 6.69 inch (170 mm) pattern. After looking a little bit I saw that the 2001 uses the same pattern as 1999 and up. Only thing I saw was an offset problem with the 2005+ on the front. I really could use a spare guys. I use this truck only to pull a trailer with my race car in it. I made a trip to Tulsa once and am not brave enough to try it again without a spare. :p
