newbie 62 uni cab mounts
Hello, name is Anthony, located upstate n.y. picked up a decent 62 unibody short bed over last winter... it seems I've searched high and low with no luck, hoping some one here can point me in the right direction!
I'm looking for the front cab to frame mount rubber pads and bolts. Any information would be greatly appreciated! (I already have the metal Mounts just need the rubbers as mine are squished pretty bad Great site will be coming here often. |
Any help would be greatly appreciated ... if the information is already posted somewhere here let me know, still learning how to navigate the site
I've got the same truck, but a long bed. Check our Macsautoparts.com. I'm pretty sure they have the pads (maybe not as a separate item, but certainly as a kit that includes the pads and bolts.
Jim |
You need to buy a regular cab kit for 61 to 64 and throw away the rear mounts.
New rear frame under mounts and blocking can be made for reinforced rubber and new red oak blocks. No one makes these. The Rad support kit for 61 to 64 is the same. you can get them just about anywhere. Garbz |
Thank you! Exactly the answer I was looking for!
