egr troubleshoot help
hey guys I have had my 01 f150 4.6 for about 6 months now. Has always run a little rough but just barely noticeable. The last month or so my cel has been on and getting a p0401\p0302 code for egr insufficent flow and cyl 2 misfire. I know it is firing on 2 because I have replaced all coils and plugs since I bought it. My main question is should I look at dpfe sensor or vaccum solenoid or since the 401 code has the 302 along with it should I look towards pulling the manifold and plenum to clean blocked passages?
Originally Posted by blueovalbigblock
(Post 13555466)
with TBH removed then one can remove the Idle Air Control (IAC) and clean it as well. the 2 previous things to do are considered just good maintenance and may not address the 401 code the 302 hints that there is issue with the #2 cyl coil and or plug or the connection to the coil. look the vacuum lines over carefully that are associated withe EGR sytem |
