2011 f250 6.2 exhaust systems?
why does every aftermarket system only fit a crew cab? if it only involves cutting pipes ill buy one but no company can give me an answer.
IMHO, you will have as good or better fitting system (and quality) if you have a local shop build & install.
I don't have a real good shop around here and I really like the Gibson exhaust. It don't make sense that they only off for a crew cab
Its only for a crew cab because thats the longest amount of pipe needed. Theres one piece in every kit that you cut to length for the cab/bed configuration
I used a flowmaster cat-back kit on my '11 super cab. It worked out great. Its not obscenely loud unless you put your foot in it, and the only cutting I had to do was cut the old stuff out of the way.
so basically its just shortening pipe? im tempted on buying this gibson exhaust (9118 kit) but i just want to make sure that it just involves shorting pipe than it turning into a big mess
