Smog test with EGR delete in Nevada
I just moved to Nevada and have had an EGR delete. Will it pass inspection like this? If not what do I do?
What does the smog test consist of in Nevada?
Originally Posted by Wayne Eady
(Post 13538971)
Where would I look for the cooler and valve?
Here in Vegas they do a visual, and dyno test. The vehicle goes on the rollers, probe in the pipe, and they'll mildly get it up to 45mph or so. As long as you aren't blowing clouds of smoke, it'll pass the sniffer test. When it comes to the visual, most smog techs have no idea what they're looking at. They will check for a cat, fuel cap, and glance under the hood. I had my nitrous system installed, and still passed. lol
Originally Posted by william_04_x
(Post 13539852)
That Nitrous just helps them burn Cleaner don't it LOL |
(Post 13539852)
Originally Posted by mustang_309
(Post 13539809)
It depends on how the EGR was deleted, if the EGR cooler was completely removed it won't pass the tampering law, if it has the stealth delete ( EGR cooler gas pass plugged at both ends ) you will be fine. You need to see if the EGR valve is even still there. Worst case scenario you will have to return the truck to stock by having the EGR cooler and EGR valve reinstalled if they were removed.
Egr cooler location
http://image.truckinweb.com/f/tech/1...egr-system.jpg |
There are counties in Nv that do not require smog inspections.
Originally Posted by POORBOY1964
(Post 13539923)
Egr cooler location
Originally Posted by olfordsnstone
(Post 13539946)
I have the EGR delete and get my smog done at a smog station next to the Emerald Casino in downtown Henderson. I have done probably five or six smog checks on my truck there and never had a problem. Most of these guys are only concerned that you pass the sniffer check and check your gas cap and exhaust.
There is a place in North Las Vegas on Nellis across from the AF Base charge less than other smog places.
The on in Henderson is Forty bucks
