one quick easy question...
how does one turbo a carbureted engine? does the turbo go before or after the carb?
There are "blow through" carbs for turbo/supercharged motors.
Pro Systems - Blow Through Carburetor Blow-Thru Carburetors Discussion from a supercharger outfit: Blow Through Carb Considerations The other way is a pressurized box for the carb. Older Ford (Paxton and others) systems used that. Google Image Result for http://forums.nmradigital.com/attachment.php?attachmentid=1184&stc=1&d=105262381 7 Pete Disher presents The Best 1968 Shelby Webpage !!! Paxton You can "draw through" as well, but with gasoline, you now have a pressurized intake system full of air/fuel, and if you drop a valve or have an ignition fubar, you will have a mini version of this: http://farm3.staticflickr.com/2272/2...7321ee0b_o.jpg |
