Originally Posted by Lance Helmert
(Post 14256299)
So with no new posts I'm assuming the new box is working good? Hope it is. Would you buy another one? Thanks for all your helpful threads.
Thanks for the input I followed this thread and can see one that had problems. What type of problems have other RedHead owners had? Is the general consensus that these are good just have a few bad one every now and then? Or is it better to get a Ford Reman?
Originally Posted by rowekmr
(Post 14264216)
1. A reman is a reman and always carries a risk that the reman was not done properly. 2. The steering boxes for these trucks (OEM from the factory) in my opinion were not sufficient to handle the needs of an EX. Some have made it 100k plus without issue but a large majority have not. 3. Based on #1 and #2 I would not install a Ford Reman, therefore I went with Redhead. I did have a loose valve in mine and had to have it warranty replaced. You run that risk with any part, which is why the most important step in deciding is "what's the warranty". |
Reman or rebuilt, less money, same thing. Redhead claims to bore for needle bearings but it's only to salvage worn out cases that were originally shaft to case (no original bushings) so that could be one out of 500. This is a discussion right?
Originally Posted by EXv10
(Post 14266681)
This is off their website and while the Ford boxes came from the factory with needle bearings a lot of the older boxes didn't, They do size every box with over size ball bearings to take out all play in the box.
Red-Head Steering Gears Re-manufacturing Process • Machining out the housings and installing needle bearings •Flame-spraying or replacing the shafts as needed Installing new control valves on some applications •Custom fitting each worm & piston assembly with special ordered, precise over-sized ball bearings. |
Here is what they do on a A1 Cardone, no wonder they call them a spray and pray..:-hair:-hair
100% computerized hydraulic testing measures for proper flow, leakage and performance to ensure perfect fit and function. • 100% new o-rings and lip seals ensure no leaking and long-lasting performance. • All critical components (campacs, spool valves, etc.) are triple-tested to ensure product reliability. • Rust inhibitive "Cool Dip" finish is a penetrating dye that completely covers all exposed surfaces for a consistent, protective finish that will not crack, flake or peel. • Shafts are surfaced to precise specifications to eliminate premature seal wear and extend gear life. • Units are supplied with 100% tested and calibrated pressure relief valves for guaranteed performance |
Been looking at these Redhead steering boxes for a while...subscribing.
http://instantrimshot.com/classic/?sound=crickets |
Here is the rebuilt process from another cheap auto parts rebuilder..
•Internal components are inspected for wear and replaced if necessary •Gear boxes are factory pre-set to OE specifications •New OE quality O-rings & seal packs provide leak proof installation •Input and output shafts are inspected and replaced when necessary to ensure quality and performance •Mounting threads are cleaned and hand chased for easy installation Wow,Good thing they clean them threads.. |
Originally Posted by Bigpipes 35
(Post 14266925)
Read between the lines. I'll be back tonite............busy
(if they don't start deleting everything) |
(Post 14266824)
Yes it is a discussion now can you post proof that they only bore out 1 in 500 steering boxes or is this Brent logic at work ?
(Post 14266872)
Red-Head Steering Gears Re-manufacturing Process • Machining out the housings and installing needle bearings •Flame-spraying or replacing the shafts as needed Installing new control valves on some applications •Custom fitting each worm & piston assembly with special ordered, precise over-sized ball bearings. >Nope, it said needle bearings when needed on worn out non bushing cases. >Yes everybody fixes or replaces things that are needed. >You have to either grind the steering worm and install bigger balls or replace it. (special ordered precise bigger balls) ......no way around it unless you want to make a steering worm which ain't gonna happen. |
(Post 14266904)
(Post 14266925)
•Internal components are inspected for wear and replaced if necessary •Gear boxes are factory pre-set to OE specifications •New OE quality O-rings & seal packs provide leak proof installation •Input and output shafts are inspected and replaced when necessary to ensure quality and performance •Mounting threads are cleaned and hand chased for easy installation Wow,Good thing they clean them threads.. I'm glad they cleaned the threads........lol, but they "say" they chase them to which others may or may not do. (we will never know). |
