Cab bushing removal
The truck is a ford 1994 F250
I was perusing the interwebs for a way of replacing the cab mount bushings that didn't involve destroying the inner sleeve hardware. I was coming up empty. Those who have had to wrestle with pulling the sleeve apart know what I'm talking about I gave it some thought and came up with this. It's really easy so I just had to share. The methods I did find were..... A.) Remove the cab and insert a longer bolt into the nut and whack away at it with a sledge hammer. B.) Cut the sleeve in half with a sawzall. I did this on one side and welded the sleeve back together. Thats when I said to myself "This is stupid. There's got to be a better way". Here's what is needed for the new method: - steering wheel puller - original bolt - 3" PVC Schedule D coupling (The thick stuff) - 4" Coffee can (optional I think) 1. Slice the PVC lengthwise so it can be collapsed around the bushing 2. Slice a portion of the coffee can, about enough to cover 2/3 of the PVC pipe. It just happens the coffee can Ifound worked out perfectly. Again the can may be optional. Fans of duct tape can use that or maybe use nothing at all. 3. Place the new contraption over the bushing. 4. Place the steering wheel puller over the pipe, insert the bolt into the nut portion of the sleeve and crank away. Make sure the bolt does not thread into the steering wheel puller, The one I used happen to be big enough to let the bolt slide freely. Here's some pictures Cab mount before. Sure it's rusty it's the Northeast and it was a plow truck. https://lh3.googleusercontent.com/-1...0620.JPG?gl=US Tool https://lh5.googleusercontent.com/-r...0622.JPG?gl=US Tool inserted over bushing https://lh3.googleusercontent.com/-g...0623.JPG?gl=US After removal. It had no problem pulling apart the sleeves. https://lh4.googleusercontent.com/-1...0624.JPG?gl=US |
Welcome to the forum.
Not a new Idea, been around for years |
Originally Posted by bldblu
(Post 13510565)
I was perusing the interwebs for a way of replacing the cab mount bushings that didn't involve destroying the inner sleeve hardware. I was coming up empty. Those who have had to wrestle with pulling the sleeve apart know what I'm talking about I gave it some thought and came up with this. It's really easy so I just had to share. The methods I did find were..... A.) Remove the cab and insert a longer bolt into the nut and whack away at it with a sledge hammer. B.) Cut the sleeve in half with a sawzall. I did this on one side and welded the sleeve back together. Thats when I said to myself "This is stupid. There's got to be a better way". Here's what is needed for the new method: - steering wheel puller - original bolt - 3" PVC Schedule D coupling (The thick stuff) - 4" Coffee can (optional I think) 1. Slice the PVC lengthwise so it can be collapsed around the bushing 2. Slice a portion of the coffee can, about enough to cover 2/3 of the PVC pipe. It just happens the coffee can Ifound worked out perfectly. Again the can may be optional. Fans of duct tape can use that or maybe use nothing at all. 3. Place the new contraption over the bushing. 4. Place the steering wheel puller over the pipe, insert the bolt into the nut portion of the sleeve and crank away. Make sure the bolt does not thread into the steering wheel puller, The one I used happen to be big enough to let the bolt slide freely. Here's some pictures Cab mount before. Sure it's rusty it's the Northeast and it was a plow truck. https://lh3.googleusercontent.com/-1...0620.JPG?gl=US Tool https://lh5.googleusercontent.com/-r...0622.JPG?gl=US Tool inserted over bushing https://lh3.googleusercontent.com/-g...0623.JPG?gl=US After removal. It had no problem pulling apart the sleeves. https://lh4.googleusercontent.com/-1...0624.JPG?gl=US And remember--if it wasn't for questions like mine, "A" grades in school would be meaningless. :-X22 Thanks. |
When one of my front mounts wouldn't come loose, I just cut it out. Easy and quick.
Originally Posted by BigSix1
(Post 13540482)
Maybe I'm dumb, or not judicious in my choice of beverage, but I'm not getting it (despite Brad's easy grasp of it). Do you have any pics of your puller hooked up? Does it pull the whole (rubber) shebang through the cab mount "perch"?
And remember--if it wasn't for questions like mine, "A" grades in school would be meaningless. :-X22 Thanks. About 4th post down https://www.ford-trucks.com/forums/1...csb-build.html |
And remember--if it wasn't for questions like mine, "A" grades in school would be meaningless. Thanks.
Originally Posted by Diesel_Brad
(Post 13542038)
VERY impressive, as always. Thank you. I read some of the thread as well, but your talent and motivation tend to overwhelm us mere mortals. But don't think I won't PM you if I get stuck, sometime. :-X04 |
Just remember there are no dumb questions and it's more than likely my choice of beverage.
The bushings are sandwiched together with a two part sleeve and what we're trying to do here is pull the sleeves apart wthout destroying them (I hear they're expensive) Once the bottom half sleeve is out you can just pull of the bottom bushing down and away from the top half sleeve and then jack up that corner of the cab so the top bushing can be removed along with the top half sleeve. Picture the contraption over the bushing and it's snug up against the bottom of the perch. Then hold the steering wheel puller over the PVC and Insert the bolt through the puller into the nut on the bottom sleeve and tighten. The bolt just slid through the center hole in my puller and the bolt head did not so it all just worked. I had already pulled it apart when I realized I should have taken a "before" picture. The last picture shows the bottom half sleeve still connected to the bolt which is through the puller. I'm probably making it more confusing. I'll post a picture of it in action. That's all we're really missing here. |
(Post 13545110)
The bushings are sandwiched together with a two part sleeve and what we're trying to do here is pull the sleeves apart wthout destroying them (I hear they're expensive) Once the bottom half sleeve is out you can just pull of the bottom bushing down and away from the top half sleeve and then jack up that corner of the cab so the top bushing can be removed along with the top half sleeve. Picture the contraption over the bushing and it's snug up against the bottom of the perch. Then hold the steering wheel puller over the PVC and Insert the bolt through the puller into the nut on the bottom sleeve and tighten. The bolt just slid through the center hole in my puller and the bolt head did not so it all just worked. I had already pulled it apart when I realized I should have taken a "before" picture. The last picture shows the bottom half sleeve still connected to the bolt which is through the puller. I'm probably making it more confusing. I'll post a picture of it in action. That's all we're really missing here. Thank you for your comment about "no dumb questions" and you're probably spot-on about the beverages. And I KNOW you're right about some pictures of it "in action." Then, even I could probably grasp it. I'm having trouble visualizing the bushings at all, as I thought these were just rubber doughnuts that pushed through the perch, LIKE A GIANT GROMMET. (I capitalize not to yell, but to tell you where I'm at, comprehension-wise). Thank you for your efforts, and all you wrote. When you get a chance, I'm sure pics will help, as you suggest. Thanks again, BigSix! |
Hi BigSix
Here's the much anticipated extra bonus pictures. Hope they help. I already had all the bushings removed but I stuck the the tool in place with a wrench on it anyway. Tool in action https://lh4.googleusercontent.com/-X...6/IMG_0653.JPG Upper bushing on top and lower bushing Upper sleeve on top and lower sleeve / bolt with washer. Washer is for the inside of cab.https://lh5.googleusercontent.com/-a...0/IMG_0656.JPG Everything put together (minus the perch of course) https://lh3.googleusercontent.com/-S...0/IMG_0655.JPG Tool over the assembly https://lh4.googleusercontent.com/-6...0/IMG_0644.JPG What the assembly looks like. This is a bracket for the radiator support. It serves the same purpose as the cab support bracket but it's a lot smaller. You get the picture (literally). https://lh3.googleusercontent.com/-x...0/IMG_0650.JPG |
