OBD1/OBDll
How many people here have an X that is OBDl or OBDll compliant. Just wondering as I scanned my wifes car for a problem this past weekend, and for the hell of it decided to scan my X, it shows up as OBDl using the Torque app. Also the emissions sticker under the hood does not say that it's OBDll compliant
I have a obd2 compliant model.
All California models and Canadian models are OBD2 from what I have read. Main differences are they have EGR and an oxygen sensor after the CAT. There is also better monitoring of misfires for each cylinder. I am sure there is more. I also use Torque pro |
Mine doesn't have a EGR or after cat 02.
It monitors misfires good had a coil go out, and within a city block the CEL came on, plugged it in, gave me the cylinder # that was bad. |
Originally Posted by hav24wheel
(Post 13432222)
All vehicles built after 1996 with the exception of a few 1995 models are OBDII. Federal requirement.
Originally Posted by Treker58
(Post 13432232)
Were you using the Torque app or a scanner, if a scanner what type?
Originally Posted by fordno1
(Post 13432237)
(Post 13432237)
The gvwr excluded the Excursion. |
But, u must remember, they use the same plug under the dash as the OBDII vehicles.. So, alot of times they are called OBDII
Originally Posted by az_r2d1
(Post 13431980)
There's no California model for the PSD's.
(Post 13432237)
IIRC, the V10 forum has a lot of info regarding this topic. Stewart |
(Post 13432539)
Look at the emissions sticker under the hood. If' it specifically states "Califonia" and/or "OBD II", then that is what it is. It it states neither of the above, it's a "Federal" with OBD I software. http://i59.photobucket.com/albums/g3.../Exsticker.jpg Mine doesn't have a EGR or after cat 02. It monitors misfires good had a coil go out, and within a city block the CEL came on, plugged it in, gave me the cylinder # that was bad. |
Originally Posted by projectSHO89
(Post 13433238)
They use OBD II hardware and communications, but they're "brain-damaged" back to only OBD I calibrations in software.
Look at the emissions sticker under the hood. If' it specifically states "Califonia" and/or "OBD II", then that is what it is. It it states neither of the above, it's a "Federal" with OBD I software. http://i59.photobucket.com/albums/g3.../Exsticker.jpg Would you mind going and checking the label? If it's OBD I, it takes an extremely severe misfire to set a fault code. Mild misfires seem to go unreported by the misfire monitor. |
OBDII was mandated by the federal govt for all 1996 model year cars and trucks. No vehicle was exempt. This standardized the ALDL connection so all were the same and it also mandated the connection was to be placed inside the vehicle in or around the dash. However, some like VW, like to hide it behind the ashtray. OBDII standardized the codes. All vehicles use the same numbers for the same general things. Misfires and the like. However, most manufactures have vehicle specific codes for their systems because of special functions. That is why 1 tool will diagnose every vehicle with a CEL on. Cheaper tools will give a code but it may not tell you the part or system that is causing the CEL. All vehicles will give a data stream for ease of diagnosing a CEL. Not every scan tool will give all information regarding a data stream because of the software. A $100 scan tool can't do the same as a $1000 scan tool. They will both tell you why the light is on but the $1000 tool will tell you more information and do more for you. It's all in the software. Why do you think OBDI in the Ford line was a pain through the 1980's into the 90's. Hard to diagnose problems. Very little information was given. Data stream was terrible. GM did a fantastic job. A lot of information was given. Data streams gave a lot real time sensor readings. That is the difference between the 2. Nobody has OBDI after 1996.
(Post 13433329)
I guess you ignored what was said above. The excursion sold in the US (except Cali models) are not obdII compliant. |
(Post 13433329)
I was under the same impression, and when the guys here let me know I was wrong, I looked at the info they posted for my benefit, then corroborated the facts with my own research. Please don't stubbornly stand by your statement when several of us have informed you of the exception to the OBD II requirement. Please do some research and you will find the same info. Like I said earlier, the V10 forum covers this topic extensively: https://www.ford-trucks.com/forums/5...ml#post3889931
Originally Posted by Krewat
(Post 3889931)
Ever wonder why your MIL/CES light doesn't come on for certain things?
Misfires, dirty MAF, bad IAC? Many trucks over 8500lbs only have OBD-I not OBD-II. Same computer, same communications, but certainly a different threshold for certain things, and other things are just plain gone. This is from 2001: http://fords.kilonet.org/krewat/images/obd-1-2001.jpg For the rest of the years, go here: http://www.motorcraftservice.com/vdi...&menuIndex1=56 In the sheet for 2005, Ford mentions phasing in OBD-II in trucks, and some Federal spec trucks may still be OBD-I. |
