BOUGHT ALL NEW OEM PARTS FROM FORD STILL CODE 629
Well Wed. I went to Ford and bought all new OEM parts that could be a possible problem and reason I am getting 629 code. I bought:
New transmission Harness ; New solenoid pack ; new MLPS ; New Torque Convertor ; new di-electric grease ; new vss ; new filter ; 16 qts fluid. Finished putting it all in this morning, and still I have a code 629 !!!!! as soon as the relays click and the fuel pump whines the first code out of the gate during KOEO is 629 then 629 then 1 then 11. ANYBODY EVER HAVE THIS HAPPEN? O/D STILL HAS NEVER FLASHED AND I HAVE REPLACED ALL REAR BULBS AND CHECKED FUSES. The only 2 that have no power on either side are in the engine compartment fuse box 5 amp and 5 amp LH AND RH TRAILER LIGHTS . :-X16:-hair:-huh |
It would be much easier for others to provide input if you would stick to one thread. You started asking for advice here: https://www.ford-trucks.com/forums/1...y-own-ass.html
You were given some suggestions and troubleshooting methods in that thread. I also tossed out the idea the driver transistors in the Torque Converter clutch circuit (inside the PCM) may be damaged. With all the parts you tossed at this problem that is about the only thing left. You could hook your meter up to the signal wire, run the KOEO test then observe if there is any voltage applied. It may take several tries to capture because of the sample time on most DVMs. Compare the findings by using the same technique on a different signal to the transmission such as Solenoid 1, 2, etc. This is one of those situations where an oscilloscope would be very handy. |
You need to stop throwing parts at it, and actually do some diagnostics. Start by getting a multimeter, and checking continuity between the solenoid connector, and the TCC lockup pin on the main ECU connector. Then verify that you are getting battery voltage down to the correct pins on the transmission connector.
E4OD pinout here: http://i275.photobucket.com/albums/j...DConnector.gif You can find your EEC pinout here: Ford Fuel Injection |
Originally Posted by Lead Head
(Post 13400126)
E4OD pinout here: http://i275.photobucket.com/albums/j...DConnector.gif You can find your EEC pinout here: Ford Fuel Injection checked all solenoids per the ATSG pinpoint test all ohm at 20 ohms checked engine ground to pin 4 p/y and pin 5 br/o no continuity applied power to pins 2 3 4 5 and could hear solenoids activate. maybe PCM relay is faulty ? |
should have just swapped in a manual trans. cost the equivalent of peanuts, just a bit of labor.
Check for continuity between Pin 4 on the transmission connector, and pin 53 on the EEC main connector.
The EEC main connector is located on the drivers side of the firewall. It's a big rectangular connector with a bolt in the middle. Undo the bolt, and the connector should come out. |
All the time & money you could of had a shop fix it & you would of been on your way.
Craig |
Originally Posted by kermmydog
(Post 13400970)
Craig Shops around here suck hind teat. Before you know it your vehicle is setting on blocks in their yard with a mechanics lien on it. I may be spending some money but I usually am driving it around at the end of the day. Though it shifts like crap. Any thoughts on voltage spikes from the Alternator? I saw my ALT gauge do a couple of two steps today. |
UTOH-AHCRAP
Originally Posted by '89F2urd
(Post 13400484)
by a friendly IED. It would be something to see which wore out first https://www.ford-trucks.com/forums/a...ctureid=135595 http://1.1.1.3/bmi/images.ford-truck...lies/eek-2.gif plus my kids are almost old enough to drive and it hard for them to do more than two things at once. :-X04 |
(Post 13400640)
Originally Posted by knotEdog
(Post 13402051)
I have been contemplating that very idea, except for one down fall caused
by a friendly IED. It would be something to see which wore out first https://www.ford-trucks.com/forums/a...ctureid=135595 http://1.1.1.3/bmi/images.ford-truck...lies/eek-2.gif plus my kids are almost old enough to drive and it hard for them to do more than two things at once. :-X04 there is one precious result being overlooked here whose benefits, in the end, far outweigh the costs required to achieve said results along the way. whats this '89f2urd!? experience and knowledge is priceless. I've never paid anyone to work on anything of mine. . .if you don't start by changing an oil you'll likely never build a motor. . . it may be frustrating, but you'll be that much more capable as a result of the process. |
(Post 13402056)
The purple and yellow wire? At the firewall block for the PCM ? With harness unplugged from the trans and the PCM or back probe (duh nevermind backprobing would give me circuit resistance or voltage) Okay I'll check that and report back.
(Post 13402441)
Yes the P/Y wire. Just keep in mind that the wire may still not be purple and yellow at the PCM connection. Luckily numbers are embossed into the end of the connector, so you should be able to count them out.
Question? How could I be getting code 629 during the KOEO which from reading in here is a TORQUE CONVERTER CIRCUIT FAILURE caused by PCM reading excessive slippage condition from TCC if I havent even started the Vehicle? :-X19 |
(Post 13404943)
The ECU does a electrical check of its system just before you start the engine. Sounds like you have a shorted wire somewhere. Or possible a bad ECU(shorted driver for that circuit) You said you have continuity from the ECU pin 53 to the transmission connector pin 4. But did you check for continuity with other pins of the ECU to that pin 53? There should be no other continuity with any other pin with ECU and transmission harness disconnected. If that is good. Then replug the ECU back in(hope you had the battery disconnected during these testes). Remeasure continuity again from the ECU pin 53 to other pins. It will be hard to back probe the ECU harness in place, but I use a straight pin to poke into the wire. There should be no continuity, if so, then the ECU is bad. |
Originally Posted by Eddiec1564
(Post 13404952)
You said you have continuity from the ECU pin 53 to the transmission connector pin 4. But did you check for continuity with other pins of the ECU to that pin 53? There should be no other continuity with any other pin with ECU and transmission harness disconnected. If that is good. Then replug the ECU back in(hope you had the battery disconnected during these testes). Remeasure continuity again from the ECU pin 53 to other pins. It will be hard to back probe the ECU harness in place, but I use a straight pin to poke into the wire. There should be no continuity, if so, then the ECU is bad. But Im on it right after I take a 30 min break to soak my leg. Its a bitch getting under truck and into engine compartment. Will post findings GONE TDY 30 min :D |
