Parts Help
I have a few miscellaneous parts that I need for my 61 unibody and could use some help with parts numbers if anyone has the time and resource to look them up. I have found a number of these parts as reproductions but would prefer to try and locate some NOS if possible.
Drivers side door arm rest Mirror extension arm (round mirror on door) Dome light lense and housing Turn signal lever Radio antenna Window crank knob Inside door handle Battery hold down clamps and hardware Shifting lever knob (3 on the tree) Glove box liner Thanks in advance. |
Originally Posted by TruBlu61
(Post 13332399)
Drivers side door arm rest The color is? Mirror extension arm (round mirror on door) Only sold with mirror. Dome light lens and housing Turn signal lever Radio antenna Window crank knob Only sold with crank handle. Inside door handle Battery hold down clamps and hardware Shift lever knob (3 on the tree) :-missingt Have fun installing it! Glove box liner |
Need parts
(Post 13332399)
Drivers side door arm rest Mirror extension arm (round mirror on door) Dome light lense and housing Turn signal lever Radio antenna Window crank knob Inside door handle Battery hold down clamps and hardware Shifting lever knob (3 on the tree) Glove box liner Thanks in advance. Side Mirrors Turn Signal Lever Sun Visors Horn Dome Light (complete) Door Locks (My Doors lock, however, I have no key lock to get into truck once it is locked) Seat belts Dual Master Cylinder (brakes) Rear bumper ?? These are just a few of the items and I only know of Dennis Carpenter Reproductions, however, could not find everything. Thank you to anyone that can help me out!! |
I've got the dome light and I've also got the horn(s) if your talking about the ones that mount on the core support and not the steering wheel horn button. Also have the sunvisors, door handle and window crank.
