Greasable spring shackel bolts
Anyone know if greasable spring shackel bolts are available for a 2002 F250 XLT 4x4?
I too have been search for these elusive parts. I asked Clay at RR and he didn't know of any either???
Thats a worry, if the yanks don't got em no one is is.:(
Sorry Brian,
I mis read your question. I found some JC Whitney greasable shackles but I couldn't find any greasable pins to compliment them. I also wasn't too impressed by the pictures of their kit? It didn't look beefie enough (I may be wrong) About the only thing I can think of is to get my stock pins drilled and tapped. Now I am not sure how much strength that will take away????? |
Originally Posted by WA F250
(Post 13358943)
Sorry Brian,
I mis read your question. I found some JC Whitney greasable shackles but I couldn't find any greasable pins to compliment them. I also wasn't too impressed by the pictures of their kit? It didn't look beefie enough (I may be wrong) About the only thing I can think of is to get my stock pins drilled and tapped. Now I am not sure how much strength that will take away????? You would need to machine a spiral groove around the outside of the pin to spread the grease around the inside of the bush. These things are available for rice burner 4x4s, landrovers, jeeps and caravans, I have a set on my van. Puzzles me why there are none for F trucks.:-banghead |
If you are only after the shackle pins have a look at the JC Whitney's? I was looking for the whole package to try to keep it all a plush ride as much as possible. I am about to do my lift kit and wanted to do it all at once.
Good luck |
Thanks mate, I'll go check out Whitneys.:)
