Working through my Valley Oil Leak; opinions please
I'm in the process of tracking down an oil leak in my valley and would like opinions on anything I'm missing.
It started with a leaky ICP sensor ... replaced but oil continues For giggles, I confirmed it wasn't the rear main seal... check! the orange boots in the center of the valley are both dry and well sealed without any signs of being saturation in oil. Used simple green and really cleaned left & right High Pressure oil fittings... clean and dry Cleaned "Non Serviceable" plug area best I could. Seems to be ok, but I can't confirm due to location. Cleaned the IPR and it looks dry without leak... I'm trying to see the plug on the passenger side to evaluate leak possibilities... HPOP reservoir doesn't show signs of oil leaking around top seal nor areas I can see. Looked at Turbo Pedestal appears dry from what I can see. Clean CCV dog house, an although it still looks moist, it doesn't appear to have major oil runoff... So, what am I missing, or forgot to check. I can drive the truck and then soak up small puddles of oil in valley. When parked on a slight incline, it's running out the valley and down the back of the flywheel on my driveway. If I soak it up with shop towels my wife is ok, but complains I'm always under the hood. I've owned the truck for just over a month and the previous owner had a HPOP leak fixed, but obviously not very well. My local diesel shop's only answer is a new HPOP. After reading all the threads here, it can have all new O-Rings so that's positive. If I can save $600 and on a HPOP and really service the fuel bowl, High Pressure oil lines, Plenium inserts, etc... Looking for some input/suggestions.. Thanks |
Are you sure it's oil and not diesel fuel?
Clean it all up again, and then shove some rags in the valley around all of the suspect areas. Go for a short test drive and check all the rags for signs of oil. If none, drive some more until one of the rags shows oil. That should help you narrow it down.
If necessary, use more rags and tie them around lines or fittings and stuff multiple rags into tight spots to help isolate the leak. Another option would be to visit the parts store and get some UV dye and a black light and see if you can follow the trail that way. |
I'm sure it's oil because its black and thick. I'm sure the fuel bowel needs a rebuild but it's too thick to be diesel... I think. I had another suggest fuel might be the leak, being unfamiliar aside from smell how can I tell oil from diesel?
Great idea with the rags. I'll try that again. The first try they disappeared and I couldn't find them. |
Originally Posted by Jesser02EX
(Post 13303517)
It started with a leaky ICP sensor ... replaced but oil continues For giggles, I confirmed it wasn't the rear main seal... check! the orange boots in the center of the valley are both dry and well sealed without any signs of being saturation in oil. Used simple green and really cleaned left & right High Pressure oil fittings... clean and dry Cleaned "Non Serviceable" plug area best I could. Seems to be ok, but I can't confirm due to location. Cleaned the IPR and it looks dry without leak... I'm trying to see the plug on the passenger side to evaluate leak possibilities... HPOP reservoir doesn't show signs of oil leaking around top seal nor areas I can see. Looked at Turbo Pedestal appears dry from what I can see. Clean CCV dog house, an although it still looks moist, it doesn't appear to have major oil runoff... So, what am I missing, or forgot to check. I can drive the truck and then soak up small puddles of oil in valley. When parked on a slight incline, it's running out the valley and down the back of the flywheel on my driveway. If I soak it up with shop towels my wife is ok, but complains I'm always under the hood. I've owned the truck for just over a month and the previous owner had a HPOP leak fixed, but obviously not very well. My local diesel shop's only answer is a new HPOP. After reading all the threads here, it can have all new O-Rings so that's positive. If I can save $600 and on a HPOP and really service the fuel bowl, High Pressure oil lines, Plenium inserts, etc... Looking for some input/suggestions.. Thanks 2) If you need an HPOP talk to Joey about a t500. 3) my money is on the non servicable (but really servicable) plug. That was my culprit OUT |
Can the turbo pedestal leak oil? There is a lot of gunk on the pedestal and passenger valve cover back under the exhaust side of turbo...
(Post 13304200)
What is the ERB and AIC delete?
I went through the same problem, and found it to be the plug on the drivers side head. In the front, just in front and below the ICP. It rarely leaks I am told.
It has a ball and spring under it so be careful if you take it out, to replace o'ring. |
I haven't ruled out the non-service plug, but it just isn't dirty enough after my cleanings. The turbo pedestal is!
Originally Posted by bigb56
(Post 13304348)
yes it can leak. There are o rings on the top, o rings on the bottom and seals around the EBP actuator and rod.
Had the same problem the Winter of 2010 and ended up replacing my turbo pedesdal with one of these Spring 2011: Riffraff Diesel: Garrett Non-EBPV/ Blank Pedestal 99.5-03 And my exhaust outlet with one of these: Riffraff Diesel: Garrett GTP38 High Flow Outlet Problem permanently solved... I also purchased the Mechanic's Cabinet and resealed the top end while I was that deep in to the engine: Riffraff Diesel: "Mechanics Parts Cabinet" Combo kit |
(Post 13305398)
So....in summary, split up the valley with rags, then take a real close look at that 'non serviceable" plug. As a matter of fact, go ahead and jam a shop towel right uder it, and I bet that is where your problem is. |
Ok everyone, I haven't dropped this and have now had time to trace it out. It's in the front of the valley. Somewhere around the HPOP, I'll need to really pay attention see where, but at least it's in the front for now. Looks like a fuel bowl rebuild, new oil lines, and HPOP gaskets all the way around.
It's cheaper for the short time... I'll keep a watch out. The towels in the valley told the story! |
Update 7/11/13:
I have finally been able to get a good look at the under area of the HPOP. Taking suggestions I've determined my oil is from the front of the valley. With a lighted mirror I found the IPR was really gunky and oil was all around behind the IPR on the HPOP housing. I still had some gunk around the Non-servicable plug that I couldn't clean. Well yesterday at Harbor Freight I found an Engine cleaning air hose that would suck cleaning fluid and blow it out under pressure. Thanks to that little tool I'm clean now! I was able to get everywhere with the simple green and knocked a bunch of crap out. I'll drive more today and see if I can locate the leak. With just the motor running, I'm unable to see it leaking from anywhere I can access with the mechanics mirror or with my eyes. My last thought is the actual HPOP gasket that mounts it to the motor, because the resivoir seal appears tight and without leaks. |
I'm interested to see a picture or link of your new tool. That air cleaner sounds like something I'd like to have.
