caliper hittin wheel
Put new brakes on. Rotor pads caliper and hose. Now caliper is hittin the wheel. Could the caliper be wrong. Or would a wheel bearing hub assembly cause this.
Thanks Trey |
Oh yeah even replaced all again just too make sure. Is a 2wd caliper diff than 4wd? Got a hub bearin assm and gonna try that next.
Do you have the calipers mounted to the wrong left and right sides. Check the bleeder screw, it should be on the top, not the bottom.
