electric fuel pump?
recently my mech. pump went a friend of mine wired in an electric pump he had on hand. couple of questions . . . . is this "better" than a mech. pump, should i get a block off plate if i keep the electric? and a question about the wiring....... is the pump suppose to run continuously while the key is in the on position? like if i wanted to listen to the radio without truck running .... and also if the key was turned to the left for just the radio , should it be running then ??? b/c mine runs all the time? is it always pumping gas into the carb for as long as i have the key turned ? is this correct? should i just go back to mech? i know alot of ???? any help thanks a lot!!!!! by the way its a 79 350 4wd with a 400. edelbrock carb and intake .
Originally Posted by XTfx4
(Post 13224426)
(Post 13224426)
(Post 13224426)
(Post 13224426)
(Post 13224426)
Next time, please slow down and use a little more punctuation and fewer abbreviations. Your post looks like a text message and is very hard to read. |
Personally I would put a new mechanical fuel pump back on.
On a carb vehicle I think of the electric pump as a "problem solver". Vapor lock problems in hot weather? The electric pump will help. Really long cranking on an engine that has sat for a while? Electric pump will help. I run an auxiliary electric on another brand 40's era PU with chronic vapor lock problems in hot weather. Problem solved.
My dent is happy with its mechanical pump. Once I got the soggy fuel lines replaced, no fuel problems including 100 degree temps. I think the mechanical pump is best. Its simple, low cost and inherently "safe" since it stops pumping when the engine stops. I'd put a mechanical pump back on personally. |
My dent is the first vehicle I've ever had that didn't have an aux electric pump added. I ran into my first problem when I ran out of gas and couldn't get the mechanical pump to prime....
I'm now considering piggy-backing an electric one on there to help with this situation and to make starts easier. |
Originally Posted by MeanGreen460
(Post 13224618)
X2, the mechanical pump will never let you down. the last one lasted 30 plus years? chris |
One of my trucks has an electric pump installed by the PO. I'm not sure why. Anyway, it was installed to operate in Run but of course was still a problem. It pumped fuel when the ignition was in run and the engine not running (such as during a stall). Even worse, it could also keep pumping fuel during a ditch or a roll and then you've got fuel going everywhere. I installed an oil switch relay I orderer from Jegs so the pump only runs when the engine is running. Do yourself and your passengers a favour and do the same if you are going electric, or go back to mechanical.
