73-79 Parts - Parting 1978 F250 4x4, 1978 F250 2wd, & 1979 F150 4x4 - Factory Ford Topper etc. in NY
Like the title says I'm parting 3 complete dentsides. All of them are regular cabs with 8' beds. There are a ton of good parts, so email me with requests and I will see if I have what you need. All have good glass
1979 F150 - one-owner, 4x4, 4-speed (NP435 with NP203 transfer case), 300ci straight 6, clean title, sliding rear window, original Ford fiberglass bed cap (factory topper with compass emblems), working Fisher plow set-up, complete brown interior in great shape, nice grill shell, good tires on stock steel rims, etc. 1978 F250 4x4 - motor has already been removed, NP435 4-speed with NP205 transfer case, blue interior, wood flat bed, high pinion Dana 44 front axle, 16.5" wheels, round headlights, good grill shell, etc. 1978 F250 2wd - 351M, 4-speed (NP435), solid frame and a lot of good sheet metal, round headlights, etc, http://i265.photobucket.com/albums/i...psa37fbf7b.jpg http://i265.photobucket.com/albums/i...ps7a1d5686.jpg http://i265.photobucket.com/albums/i...ps3f201741.jpg http://i265.photobucket.com/albums/i...ps47ce5630.jpg |
does that 78 have a good working steering shaft ? ( between column and steering gear ). btw i'm the guy thats trying to locate a frame for you.
pm sent!!!:-jammin
I'm looking for a good cab. Where in ny?
Do you have a fuel filler hose for the rear tank? I have a 1976 F100.
Been out of town all weekend....I have two good cabs and I'll see if I have a rear fuel filler hose that is in decent shape. Will reply to pm's in the next day or so too, thanks.
np 435 wire harness
1 Attachment(s)
looking for wire harness that mates into np435 from prop valve to rear I have a 75 hb not that I think it matters
Yep, I should have one of those. The weather is looking better after tomorrow so I will be able to get up there and get a look at some of the requested items. Thanks
Im looking for headlight retainer rings.
Square or round?
How much for the discs, hubs, and all basically knuckles out on f150 4x4 plow front end. really don't need calipers and rotors unless in good shape. Needs to be dana 44 with 5x5.5 29681
Originally Posted by twinzilla
(Post 13236151)
Square or round?
I have some I'd sell you but I think they're available new from auto zone for like $6 a piece.
twinzilla where in ny are you, im at the south end of canandaigua lake (14512) also that blue truck, was that on craigslist a little while back?
i am in need of 8 lug 16" rims and tires, no split rims
