How big of tires can I fit on my F150?
How big of tires can I fit on my F150? It is a 1984 Ford F150. I would like some big aggresive tires without a lift kit.
Thanks! Andrew :-X04 |
I'm assuming your rig is 4wd since your wanting an aggresive tire. I've been doing alot of research on this lately, and this is what I've found:assuming your springs are not sagging too awefully bad and your using a factory 15X8 rim with normal offset you could use a 32x11.50 but I'm going to stick with a 31x10.50. The extra inch wasnt worth another 25-60/tire for me. I'm going with BFG all terrain TA K/O. It has a moderatly aggresive footprint but performs great on road or off and is a quiet riding tire. Depending on your needs the new Krawler series(BFG) is also a mean looking tire but be ready to pay( BIG). Hope this helps.
2WD, I just want some bigger tires! What do ya think? The spings dont seem to be sagging too bad
Thanks:-X04 Andrew |
31x10.50's are about the limit up front on a 2wd, On my 82, I got some rubbing the radius arms at full lock, and some inner fender rubbing under full compression. On the rear, I've seen 33x12.50's fit without too much trouble.
Evan |
thanks!!!
Andrew |
I agree 31's would be max on your truck.
31-10.50's all i can clear on the front of my 2wd F150, Can clkear a 35-12.50's on rear. Had to try the spare 35's of rear for kicks.
i have 33x 12.5 x15 size tyres on my 81 2wd, dont do it without doing some lift mods!! i put chunky mud tyres on mine and they wore quickly and rubbed on every part of the wheel arch possible.i am currently looking to lift mine so i can keep the tyres at that size, but without the lift spend your money more wiser and get a good 31 inch all terrain.
I found some 32's, and measured them at 31 (real measurment) I have to go out tommorow and measure up on the truck! I did not buy, but will measure first. Only 200 bucks mounted (rims and tires) and fairly agressive, but rims have the clearcoat (?) peeling up. Still a good deal tho, just hope they will fit on my truck without rubbing!
Can you fix the peeling clearcoat (maybe oxidisation) ??? Thanks Andrew |
only getting them sand blasted and then re croming them i think. dont quote me on that though. sounds like a good deal though,good luck.
i dont think 32's would fit on a 2wd, at least not very well. 31s are generally a bit smaller than an actual 31"s. when i was looking for bigger tires, all the tire shops around my house said 30x9.50's wouldn't rub. so i just said with 235-75's.
