Looking good!
Amazing... Your turning scrap yard metal back into a truck!!!
I have been through the restoration of my cab. It seems as like it took forever but it is worth all the time and effort. I have some pics that my help out if you wish to check them out.
Tim |
Nice work!Where did you buy the inners?I didn't even know they existed!:-huh
Originally Posted by Indybeer
(Post 13150819)
Started on rear cab corner....what a mess. This is going to take some time.
http://home.comcast.net/~qarre/F100186.JPG http://home.comcast.net/~qarre/F100188.JPG http://home.comcast.net/~qarre/F100191.JPG http://home.comcast.net/~qarre/F100193.JPG |
Way to go, nice work!
Hats off to you guy. That cab is looking good.
Originally Posted by Olweldinrig
(Post 13223455)
Left 7706-L Right 7706-L Cost $65 I have the LH inner that I am not going to be using since I don't plan on removing the gas tank filler, along with a couple other parts to try and sell later when I get finished with the cab work. |
very good job, I'm learning with it for my restoration
More Progress
Made a little progress this week....http://home.comcast.net/~qarre/F100229.JPG
http://home.comcast.net/~qarre/F100230.JPG http://home.comcast.net/~qarre/F100231.JPG http://home.comcast.net/~qarre/F100232.JPG http://home.comcast.net/~qarre/F100233.JPG http://home.comcast.net/~qarre/F100234.JPG http://home.comcast.net/~qarre/F100235.JPG http://home.comcast.net/~qarre/F100236.JPG http://home.comcast.net/~qarre/F100237.JPG Next week I will be starting on the LH rear cab corner.....not going to be as easy as the RH side due to the gas filler opening. |
(Post 13223455)
(Post 13237439)
I got the inners from Mid Fifty (pg 115)
Yea...once I had the pass side corner tacked into place...I temporarily installed the door so I could get it lined up.
I was hoping I wouldn't have to replace the whole drivers rear cab corner...but the bend radius and dimensions on the lower part of the new panel are nowhere close to being the same as original. Found this out after cutting what I thought I would need out of new panel....I have a new panel ordered from Mid Fifty...hope to have it next week when I am off again. |
Posted some of these in another thread about cab corners but here is the final corner of my cab that needed repaired.
http://home.comcast.net/~qarre/F100239.JPG http://home.comcast.net/~qarre/F100240.JPG http://home.comcast.net/~qarre/F100241.JPG http://home.comcast.net/~qarre/F100242.JPG http://home.comcast.net/~qarre/F100245.JPG http://home.comcast.net/~qarre/F100249.JPG http://home.comcast.net/~qarre/F100251.JPG Disassembled the rack I used while I was doing the repair work and put it back on my rolling rack...Just need to go thru it and finish welding it up. I hope to have it ready for media blasting in next couple of weeks. |
Wow! Really nice job! I can't imagine beginning a project like yours (since I have no patience and would go nutty trying to get it done). I have to give you major props for not only doing a great job (craftsmanship wise) but for doing the job methodically and correctly. Thanks for sharing your work.
Wally 1951 F1 - ol' red |
