2005 Ford Escape CEL P0171 P0174
Hello All!
Any help on this would be GREATLY appreciated! I feel like I need to start from the beginning. I had over 100,000 miles on my truck and it had been misfiring for a while so I decided to change the spark plugs. Well, for those of you who don't know, there is a bulletin (not a recall) out for 05/06 Ford escapes and others that states that the wrong plugs were put in at the factory and if you don't change all the coils when you change the plugs the pcm will burn out. Well, that's what happened to me. I had to replace plugs, all 6 coils and buy a new pcm and also pay a locksmith for a re-keying. After and because all of these were replaced, the catalytic converters (2) were the next to go. However, in the meantime I cleaned the MAF, replaced the pcv valve, changed air filter, replaced air intake gaskets, sea foamed (4 part) and an oil change. I still have these P0171 and P0174 codes. When I start the car it idles up for a bit and then settles down. When I start out at low speeds it will kinda "jerk" into gear or bog down and after that everything is fine. Engine actually sounds great. Below is the freeze frame data from my CarMD. Can anyone narrow this down by looking at this data? I am so sick of throwing parts at this vehicle and cannot afford to take it to the shop. DTC for which Freeze Frame was Stored P0171 Fuel System 1 Status Closed Loop Fuel System 2 Status Not Supported Calculated LOAD Value 76.47 % Engine Coolant Temp 176.00 °F Short Term Fuel Trim - Bank 1 13.28 % Long Term Fuel Trim - Bank 1 20.31 % Short Term Fuel Trim - Bank 2 9.38 % Long Term Fuel Trim - Bank 2 20.31 % Intake Manifold Absolute Pressure 17.77 inHg Engine RPM 827.50 rpm Vehicle Speed Sensor 0.62 mph Ignition Timing Advance #1 Cylinder 12.50 ° Intake Air Temperature 84.20 °F Air Flow Rate Mass Air Flow Sensor 2.00 lb/min Absolute Throttle Position 26.67 % Oxygen Sensor Output Voltage (B1-S1) 0.20 V Short Term Fuel Trim (B1-S1) 12.50 % Oxygen Sensor Output Voltage (B1-S2) 0.63 V Short Term Fuel Trim (B1-S2) 99.22 % Oxygen Sensor Output Voltage (B2-S1) 0.71 V Short Term Fuel Trim (B2-S1) 10.16 % Oxygen Sensor Output Voltage (B2-S2) 0.79 V Short Term Fuel Trim (B2-S2) 99.22 % Time Since Engine Start 236 sec Fuel Rail Pressure relative to Vacuum 38.16 psi Commanded EGR 0.00 % EGR Error 0.00 % Commanded Evaporative Purge 0.00 % Fuel Level Input 12.94 % # Warm-ups since DTC Cleared 4 Distance since DTC Cleared 52.82 mi Evap System Vapor Pressure -32.55 inH20 Barometric Pressure 29.61 inHg Catalyst Temperature Bank 1 - Sensor 1 1,020.56 °F Catalyst Temperature Bank 2 - Sensor 1 1,020.56 °F Misfire Monitor Complete Fuel System Monitor Complete CCM Monitor Not complete Catalyst Monitor Not complete Heated Catalyst Monitor Not Supported EVAP Monitor Not complete Complete Not Supported A/C System Monitor Not Supported O2 Sensor Monitor Not complete O2 Sensor Heater Monitor Not complete EGR Monitor Not complete Control Module Voltage 14.09 V Absolute Load Value 41.96 % Commanded Equivalence Ratio 1.00 Relative Throttle Position 6.67 % Ambient Air Temperature 69.80 °F Again, Thank you for ANY help you can give me |
