Ford Truck Enthusiasts Forums
-   1948 - 1956 F1, F100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum41/)
-   -   Rebuilt carb but now not working??? (https://www.ford-trucks.com/forums/1241359-rebuilt-carb-but-now-not-working.html)
FORD4STE 05-05-2013 12:35 PM
I just rebuilt my carb last night. It was my first time. It's the original carb on a 1950 F1. Put it back on this morning and now it seems like its not pulling the fuel over. What could have I possibly done? The pump seems to be pumping cause the fuel line going into the carb was loose and was leaking trying when trying to start. So I don't think it's the fuel pump. I'm at a complete lost on what I could have done wrong. Any suggestions on what I did wrong?
Jolly Roger Joe 05-05-2013 02:15 PM
Do you have a 6 or V8? I believe the carbs are different. The 6 uses a 1bbl Holley 847-FS, 8HA-9510-A. I think the V8 is a 2bbl.
FORD4STE 05-05-2013 02:22 PM
It's the flathead v8. Which is the Holley 94 carb.
Jolly Roger Joe 05-05-2013 02:26 PM
Well, welcome to FTE! :-wink
I don't know much about the V8, but there are plenty of folks on here who do. I'm sure someone will be along to help you soon.
I know for the one barrel, the book says to pre-adjust the idle mixture screw and idle adj screw when reassembling. If you have both (I assume you do) can you make any difference by adjusting either?
FORD4STE 05-05-2013 02:35 PM
Thank you and glad to be apart of FTE.
Well I haven't tried to adjust that yet. Not exactly sure how to be honest. There are 2 Screws there but which way to adjust? It just seems like its not pulling any fuel in. So would that be the reason?
Jolly Roger Joe 05-05-2013 02:41 PM
Try adjusting the idle mix screw out about 1 1/2 turns. The idle screw won't make much difference until you have it running.
On mine, after it's running, you turn the idle mix screw in until it starts to stall, and then turn it out a prescribed number of turns. Maybe if yours is closed (all the way in) it's not letting any air in. Do you have it choked to start? Does it smell like gas when trying to start it? If it does, then it's flooded (too much gas and not enough air). Can you see gas in the carb? Will it start if you pour a little gas into the carb?
Come on, V8 guys. Help him out! :)
FORD4STE 05-05-2013 02:49 PM
I'm not really smelling fuel so I don't think it's flooded. So I'm not exactly sure what I had done wrong.
ALBUQ F-1 05-05-2013 03:05 PM
With it still on the truck, take the upper body off. See if there is any fuel in the bowl. The float may be stuck or hanging up on something.
FORD4STE 05-05-2013 07:59 PM
I just took the upper body off and it had a small pool of fuel in it. The float moves freely when I worked while I had it off. So with that said, why is it not pulling fuel?
ALBUQ F-1 05-05-2013 08:06 PM
Does the needle fall down of its own weight when the upper cover is right-side up? When the top cover is inverted, is the tang from the float to the pivot shaft about horizontal?
FORD4STE 05-05-2013 09:10 PM
Yes te needle falls on its own and re tang looks to be fairly horizontal.
ALBUQ F-1 05-05-2013 09:19 PM
Pull out the needle and seat, see if there's something in the passage from the inlet to the seat. Blow it out with air. Make sure the seat is drilled properly, you never know.
aussiecowboy 05-06-2013 01:41 AM
Sounds like a needle and seat issue to me as well. If the pump is pumping and bowl isn't full, that's really all it can be.
The Horvaths 05-06-2013 06:21 AM
Look for a sintered bronze filter hiding at the fuel inlet. If you find one, replace it as either your needle's sticking, the float's set wrong, there's a clogged filter, or you're now out of gas. Assuming that the pump still works, of course.
Rojak 05-06-2013 08:21 AM
Welcome to FTE Ford4ste! Keep us posted on your progress. I have a similar situation with my 48 F3 (w/6 cyl). Rebuilt carb and it won't start. I've got several things to check out but I'll be looking at my carb based on the advice here. Thanks all!
