1999-2007 Ford F250 Truck Super Duty Mirror Power Heated Signal Clearance Light Telescoping UPGRADE
CHECK HERE FOR GREAT PRICES 1999-2007 Ford F250 Truck Super Duty Mirror Power Heated Signal & Clearance Light Telescoping UPGRADE Pair
FREE SHIPPING IN THE LOWER 48 STATES!!! http://static.1aautoimages.com/parti...00611/main.JPG These replacement mirrors are just what you need to get your vehicle in good looking form again! Specifications: Comes as a PAIR Fits both LH (Driver Side) & RH (Passenger Side) Power operation Heated Dual Arm Dual Glass Manual Extending Smoked Turn Signal Lens with Clearance Light Textured Caps Retrofit 2008 and Up Style Replaces dealer part numbers: 5C3Z-17683-EAA, 5C3Z-17D743-BAA, 5C3Z-17682-EAA, 5C3Z-17D742-BAA, 5C3Z17683EAA, 5C3Z17D743BAA, 5C3Z17682EAA, 5C3Z17D742BAA 180 Degree Swing 10 Hole, 7 Pin Plug Direct replacements Built to strict quality control standards These mirrors make great replacements and have good cost savings over dealer units. Special Note: This mirror is designed to replace an original mirror with these exact options. If you do not have the options listed, there is a possibility that this mirror may not function properly. 1 Year Warranty This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty. This part replaces: OE #: 5C3Z17683EAA, 5C3Z17D743BAA |
back in stock
