Please decode this 60 4x4 COLOR MODEL TRANSMISSIONS AXLE
Found this near complete but very dirty and somewhat rusty old truck in the junk yard for $1000.
Thinking about getting it so I can get the 8 ft Flairside bed for a 62 4x4. It currently has a 223 in it with a generator but I think it may have had a V8 originally as it has some AC add on stuff in the cab. Tag is on the glove box door. Last tagged 1983. F10J0K61093 WB 118 COLOR L MODEL 103 DATE 18H TRANS FA AXLE 02 GVW 5600 HP 126 RPM 4000 DSO 9229 |
Tag is on the glove box door. Last tagged 1983. F10J0K61093 Fourth digit J = 223 6cyl sixth digit = Kansas WB 118 COLOR L = dark green MODEL 103 = f100 4x4 DATE 18H = 18 August TRANS FA = Ford 3 speed (my 59 data plate says same and it came with 3spd) AXLE 02 = Rear axle 3:89 front axle 3;92 GVW 5600 HP 126 RPM 4000 DSO 9229 If I have misstated any info, Bill AKA NumberDummy will be along and square me/us away. Keep us posted on your progress and what your plans are for this truck (and of course pictures). |
Originally Posted by old broke prospector
(Post 13112560)
F10J0K61093 / WB 118 / COLOR L / MODEL F103 / DATE 18H / TRANS FA / AXLE 02 / GVW 5600 / CERT NET HP 126 / RPM 4000 / DSO 9229 J = 223 1V I-6. 0 = 1960. K = Kansas City MO Assembly Plant. 61093 = 1960 Numerical Sequence of Assembly, the trucks specific serial number. 118" Wheelbase. L = Dark Green. F103 = F100 4WD, 5,600 lbs. GVWR 18H = Assembled August (H) 18, 1960. FA = :-huh Not listed in parts catalog. F = Warner T-98 / A = Ford 3 speed light duty manual trans. 02 = Ford 9" Rear Axle / 3.89-1 / No Limited Slip * / 3,300 lbs. Rear Axle Capacity / No 3rd digit of AXLE code listed which refers to front axle. 5,600 lbs. Gross Vehicle Weight Rating. 126 net HP @ 4,000 RPM 9229 = Domestic Special Order number. Truck was ordered special by original purchaser, not "bought off the lot." * mercurytrucks.com (link in post 3) clueless: 1959 thru today: If the AXLE code begins w/a letter: Limited Slip / If with a number, no Limited Slip. |
