is There any diffrence between 96 and 02 7.3 block and crank
I have a 02 with a rod knocking and 96 engain that floated the valves, Can I use the 96 to fix the 02?
Second what is a 7.3 block and crank worth? |
You can get a set of rods for reasonable. I would recommend getting new forged rods. And there is only a difference in the front covers.. but for the life of me I cannot remember what specifically that it.
I believe I sold a sleeved block/crank/cam that was ready for a hone for $500. |
2 Attachment(s)
The blocks and crankshafts are different between those years.
Here are a couple of files that explain the differences. |
Well then.. guess i'm the jack@ss.. thanks for the info greg
Good stuff greg...
Thanks for posting |
Originally Posted by jkidd_39
(Post 13067184)
The lifter guide style is different as well. It says the newer style crankshafts are stronger so I suppose they would be more desired. :confused: |
1 Attachment(s)
I remember reading something about head gasket changes through years as well. I will try and find that page...
Here it is. The newer style F-250/450 gaskets will fit the older blocks so that works out. There is a thinner F-650/750 gasket that creates a higher compression ratio. This is a good way to identify a 650/750 engine at a salvage yard since the corner of the gasket will be visible (also there should be a fuel pump in the valley of the engine). |
I've wondered what drove the fuel pump on the pre 99 power strokes, was it a lobe on the cam shaft? I had a 95 and remember the fuel pump being in the valley. If so the cam would be different.
1 Attachment(s)
Originally Posted by stinson 108-1
(Post 13067765)
Thanks Greg, As I said, thats something I wondered about. Didn't Know about the valve timing either.
Thanks, If the crank will bolt up to flexplate it still might work. How is the fuel pump hole in the vally pluged on the newer trucks.
Originally Posted by Red454sedgwick
(Post 13068064)
