Time to buy some gauges - what are you using?
I just got the truck back from being studded along with some other upgrades and updates. Truck now has an SCT tuner and 4" straight MBRP exhaust and will have an Atlas 40 FICM soon as well. Currently, Torque is setup to monitor:
Page 1 - Engine oil temp Engine coolant temp Transmission fluid temp Battery voltage FICM main power IPR PSI Page 2 - Boost (I've got the boost gauge in the cluster, so kind of pointless) Current gear Fan RPM IPR % Engine load % VGT % It seems besides EGT and low pressure fuel Torque has it covered. I know both of those require a sending unit and temp probe hooked up to a gauge or monitor. Most likely I'll just mount them on the A-pillar as it seems the best location and will be mounting my phone on top of the dash using a phone mount near the A-pillar. Is there anything else you guys recommend? |
DashBoss with the EGT and Fuel pressure kit would get you everything without having a need for pillar gauges...
On the 12 Gauge screen I have: ECT EOT Volts FICM Main Boost Mass Fuel Desired ICP PSI ICP Volts IPR % Trans Temp Fan Speed VGT% Then on 3 screens of 4: Screen 1: FICM Synch FICM Main FICM Logic FICM Vehicle Screen2: Is my test screen.. I load up my variables there, currently: Fuel Level ICP CALC ICP Desired EBP PSI Screen 3: BARO MAP EBP EBP volts Currently working on Trans selection and ECT/EOT Spread PID Josh |
I'm perfectly fine with pillar gauges and in fact for certain items I prefer an analog gauge to read them. EGT and low pressure fuel dance around quite a bit and I would prefer them in analog readout whereas all the other listed things (besides boost and HPO PSI) don't really move around much once the truck is up to operating temperature. Boost I am fine with the analog gauge in the cluster and I've got HPO PSI on Torque. Also, there's no reason to go to DashBoss for me, especially when I have Torque already setup and it cost me more to use it compared to just get stand-alone gauges.
The boost gauge in the dash is not accurate if you are running a tuner, and the reading from the obd 2 won't be either
I'm planning on running a 0-30/40 boost, 0-100 fuel pressure and 1-1600 egt eventually. Isspro ev2 |
Another vote for Isspro EV2 gauges.
I have the old school Isspro EV's in my truck and they still work excellent. Good, quality gauges and are easy to read. http://i1207.photobucket.com/albums/...riderxx/qw.jpg |
Originally Posted by acf6
(Post 12988840)
I'm planning on running a 0-30/40 boost, 0-100 fuel pressure and 1-1600 egt eventually. Isspro ev2 Fo the boost gauge, I would run a 0-40. You guys can crank out more than 30 psi with the 6.0 if you intend on upgrading performance later on. Better to have more than not enough. Just my .02 |
(Post 12988840)
I'm planning on running a 0-30/40 boost, 0-100 fuel pressure and 1-1600 egt eventually. Isspro ev2 Josh |
Originally Posted by Km1210
(Post 12988879)
Miles,
(Post 12989058)
Ya, I just couldn't remember if they came in 0-30 or 0-40
I think 0-40 would be enough unless you're building a race truck.}> |
Originally Posted by Bullitt390
(Post 12989004)
DashBoss you choose either boost from the PCM or absolute boost from the MAP.
Josh What gauges are you ACTUALLY monitoring? Obviously some of those are really only useful if you're having a problem, and most likely you would catch that problem on another related gauge I would think. I just don't feel the need to cycle through a billion gauges. |
I really dont even look at my scangauge, it just gets me all worked up if i do. I typically display Volts, FICM main volts, oil and coolant temp. Unfortunately this has been alerting me that i need an oil cooler, as im running a 15* delta most of the time, but its not so bad yet so im putting it off
I really just want a fuel pressure gauge, i feel that is one you should always monitor |
(Post 12991543)
I honestly do not pay much attention at this point, and normally do not even fire up DashBoss unless I am traveling farther than normal, or just bored in traffic.
However, what I keep my eye on is Volts and IPR% at idle. Josh |
Can i ask (serious question) why you look at IPR %?
(Post 12991608)
