2wd tranny to 4wd tranny
What do i need to do to change the 2wd C-6 tranny over to the 4wd tranny? is it even possible or would it be cheaper to just find a 4wd C-6? Also is the C-6 4x4 tranny only a married deal or is it possible to have it divorced?
Thanks Tim |
anyone have any thoughts?
What truck are we talking about?
With the C6s changing over is just not that easy but possible .. If you've never done it then steer clear is my advice .. The divorced transfer idea is what I'm doing on my lowboy but I already had a Highboy parts vehicle .. This option gives you all kinds of tranny options not just the C-6 and they can be 2wd trannys you'll just need a custom drive shaft between the trans and the transfer case .. If done right you can reuse the drive shafts from the highboy from transfer case to differentials .. |
Originally Posted by redroad
(Post 12968259)
With the C6s changing over is just not that easy but possible .. If you've never done it then steer clear is my advice .. The divorced transfer idea is what I'm doing on my lowboy but I already had a Highboy parts vehicle .. This option gives you all kinds of tranny options not just the C-6 and they can be 2wd trannys you'll just need a custom drive shaft between the trans and the transfer case .. If done right you can reuse the drive shafts from the highboy from transfer case to differentials .. Tim |
Originally Posted by elkarcher1716
(Post 12968385)
I have all the parts. This is going in a 1975 HB behind a 390. I think i can just cut the old driveshaft and I should be good to go. Alteast that was my thinking in the beggining.
Tim |
Maybe .. not sure where you are in Nv.
Ford 390 |
Ya im in vegas. I think my C-6 has the long tailshaft.
(Post 12968664)
It had the 435 in it but its the wifes truck and she wants the auto put in. gotta keep mama happy ya know.
(Post 12968841)
I have to get the frame back from powder first. so i can get the rolling chassis started and then i can get some measurements. i wont get the frame until friday and then by sunday i should have most of it done and let you know.
Just out or curiosity are there any other Automatic trannys I could use instead that wont break the bank?
(Post 12971290)
those ain't cheap at all. been through that with my bronco.
