Floor pans 1959 F100
Does anyone know of anybody other that LMC that build floor pans for a 1959 F100. It would be even better if you know if they are available in Canada. That way the freight is less
Subscribing to this. LMC is the only place I've found them, and they're about double what I'm used to spending.
I got mine here. Good guys, give em a call.
classicfabrication.com your on-line source for floorpans for your classic car |
beautiful truck. How was the fit? They are priced a fair bit less than LMC? Did you have to replace your front floor braces as well?
what did you do for a floor in the box. Mine is rough, and replacement floor doesn't seem to exist. I can find a new from Ford floor panel that is the same size (other than mount) but could easily plug and fill them) any suggestions
Originally Posted by jamhh
(Post 12939836)
They have floor braces as well. The floor pieces are not an exact OEM match, but they work fine. Like I said, best to call and discuss with them. They are not as internet savy as some suppliers. |
(Post 12939939)
