My 1989 F150
So I've inherited my grandpa's truck that he bought brand new in 89 from Pasco, WA.
My goal is to make it look new again with some engine/suspension mods. Truck has a 5.0 with 129k on it. AOD has been rebuilt already. Interior isn't too bad on the truck. Carpet needs a little cleaning from the people who have had it for the last couple years. Dash is crack free. I've got a few things to deal with to make it road worthy again. Right now I need to redo the brakes. After that I need to deal with 2 broken bolts on the top of the waterpump. Once that's dealt with ill start with exhaust and continue from there. I definitely want to do a maf conversion. Also none of the power windows work. I think the passenger side motor is seized and the regulator or the bushings in the motor failed on the driver side. List of stuff I want to get done (not in any particular order): Long tube headers Delete smog stuff (i've passed in az without this stuff before) Heads Roller assembly stuff for the engine. HO cam Maf conversion Valve body with OD lock out from silverfoxtrans Deep pan for AOD Haven't decided if I will level the truck out or do a 3/4 drop Might do some sort of Forced Induction either turbo or supercharger. Anyways here are some pics. http://i78.photobucket.com/albums/j1...psd418c4a5.jpg http://i78.photobucket.com/albums/j1...ps93843a1c.jpg http://i78.photobucket.com/albums/j1...pscafb0ac0.jpg I put a blanket over the seat so the small rip wouldn't get any bigger and I am half tejano LOL. http://i78.photobucket.com/albums/j1...psc2de35a6.jpg http://i78.photobucket.com/albums/j1...ps12e16690.jpg Sweet curtains right? It's weird owning something that has so much history in my family. Like I said I want to make it look new again because my grandpa always talked about getting repainted since the paint went to hell when he moved to AZ |
First off glad you got the tittle thing organized out. Also wanted to subscribe because I like hearing on these projects. Hope the 302 treats you well.
Trav |
Thanks man. It was actually extremely simple. Everything worked in my favor.
Ill have to update this. I ended up pulling heads an all that fun stuff. THink I am going to end up pulling engine so I can reseal it on a stand. Engine looks simple to pull.
It is pretty simple to pull harderst part like usual is the exhaust.
Trav |
Haven't really posted much on this truck lately. Decided to ditch the 302 as I picked up an f4te 351 with 90k on it. Stripped it down to short block. Ill probably just clean the block up and put a set of tfs heads on it.
https://www.supermotors.net/getfile/...301_170428.jpg |
Update:
Finally got the 351 in and running have some running issues but at least the engine is finally in lol. |
