snyda88 |
02-23-2013 01:53 AM |
2002 F-250 7.3 wont crank when damp or raining
After having the PCM replaced by ford my truck wont crank when damp or raining. My batteries and alternator are good as tested by the dealer and they put a new starter on because they broke the terminal off the old one. I have to unplug the wire under the hood and jump it to the positive post on my battery. the ford dealer told me it was a moisture related problem (no s*#t). IDK what else to check I cut the starter wire to install a remote start (since removed to be installed by a professional at a later date) which caused this whole fiasco requiring me to get a new PCM. I checked the starter wire on the ignition harness and even re-soldered it to ensure it had a good connection. Odd though once he truck is warm after "hot-wiring" it it starts/cranks with no issue. This will be the third straight week my truck has been at the dealer unless you guys have any ideas.
