1316 code
would a bad injector cause this code
I have for P1316 possible causes (this is verbatim from the PC/ED diagnostics book):
Possible causes: - injector(s) or circuit(s) - Open or shorted IDM enable circuit - Open / short EF circuit - Open / short FDCS circuit - IDM relay - IDM powering circuits - IDM - PCM Perform KOEO On-Demand Self Test - Are IDM or any other codes stored? |
What kind of symptoms are you experiencing?
I'd bet its just a loose UVCH
Originally Posted by 123skeeter
(Post 12870937)
Just went through this. SES light came on, noticed a slight miss (not much) and started researching. After ohm testing the UVCH harness on the pass side, discovered excessive resistence on inject#5 and #7. Had a local shop diagnose and discovered 1316, ran an injector buzz test and confirmed that #5 had issues. At this point, there is only one thing to do...remove the pass valve cover. Discovered the UVCH had backed out just a bit. I could have re-inserted and performed a .50 mod, but the harness was so brittle it broke in my hand. Ordered a gasket and harness from Riff-Raff. The harness, while OE, was not an upgraded harness. Decided to try the .50 mod on the new harness and broke that new harness tab as well. This is a poor design on the harness and any mechanic with some PSD experience will say that a 1316 code almost always means a slipped harness. I ended up using zip ties on the harness. Truck runs great now. My advise is to ohm test the gasket on each side and try to determine which side has the problem, then remove the valve cover and take a look. The ohm test is a PITA, so if you have access to a code reader with a buzz test, go that route. Good luck.
Originally Posted by richea33
(Post 12873750)
Are you saying the new OE harness from Riffraff was not the revised part with the two little nubs under the retaining tab? :-huh |
The harness did have the two little tabs that locked from underneath. My old harness had those same tabs, but still pulled out. Those tabs wore out and I expected that a modified harness would have something different, perhaps tabs on the side. I thought the purpose of the .50 mod was to keep those tabs locked into place. Did the pre-2003 harnesses not have the tabs at all?
(Post 12873904)
