fuel pump issue
I have a 59 f100 with a 272 and a 2b Holley. The fuel pump was weak so I replaced with a new one. Didn't help. Any suggestions about in line electric pumps? I don't want to replace the cam if I don't have to
I researched the same thing. An in-line electric fuel pump should be no big deal - just get one with a similar psi & gph output as the engine driven one or you'll have to use a regulator too. Would also probably be a good idea to install a relay to provide key-on power to it.
How did you determine the original was weak and why would a new one still be weak?
We were having running issues, the truck would run only when fuel was poured into the carb, I checked the float and needle because the bowl was dry. They all seem to be free and working, so we removed the fuel line at the intake to the carb bowl & at the pump. The fuel coming out of the pump was just a trickle, so I replaced the pump. Now with a new pump I still only get a trickle.
It may not be a fuel pump problem. There might be a colapsed line, a plugged up line, or something like that. An electric pump will still have to fight those issues.
When you disconnect the fuel line to the pump does it flow freely from the tank?
I ve got good fuel at the supply line to the pump, and the transfer line from the pump to carb is clear
Ok, just a thought.
Originally Posted by jamhh
(Post 12834284)
Problem found. It was the rubber feed connector hose from the steel line to the pump. It was clasping under suction. Thanks everyone
Good catch. I was going to mention putting a vacuum pump with a catch jar on the supply side and see what happens when you put suction. I've found hoses that suck air but don't leak fuel too. But then I figured if you had that apparatus, you would have used it already and no sense recommending it if you didn't have one. Kinda rare but it does happen, especially if you get any fuel with alcohol.
