77 f150 351w swap???
Have questions regarding the starter i would need to use with my 351w swap.
Im going to be running the 157 tooth 10.5 clutch. Im assuming the original from the 300 I6 aint gona work? Any help would be greatly appreciated. Do you guys like pictures? lol. Ill work on getting some up Heres the 351 I built https://www.supermotors.net/getfile/...47386768_o.jpg Ill get more pics up soon. |
Motors a 74 block
https://www.supermotors.net/getfile/...97716534_n.jpg https://www.supermotors.net/getfile/...78978300_n.jpg https://www.supermotors.net/getfile/...14581370_n.jpg .040 over with speed pro pistons. nothing fancy, stock bottom end with arp rod bolts https://www.supermotors.net/getfile/...24044268_n.jpg https://www.supermotors.net/getfile/...83434960_n.jpg https://www.supermotors.net/getfile/...22887158_n.jpg https://www.supermotors.net/getfile/...165520_379.jpg cams a comp cam Grind #X4254H Duration @50 210 218 Lift .477 .493 1200-5200 rpm range 6quart Ford Racing Oil Pan https://www.supermotors.net/getfile/...165245_219.jpg E7TE rebuilt heads with new HD springs and just gasket match porting done https://www.supermotors.net/getfile/...191912_943.jpg Edelbrock Dual Plane Performer 351w intake https://www.supermotors.net/getfile/...193137_227.jpg More parts should be in today. enjoy |
I think the 300 uses a sbf starter, but I'm not sure.
I have Windsor in my 79 f150. It's been a while since I bought the starter. I think I used a 302 starter.
I know there are 2 different tooth count flywheels, the 157 and I think a 128. If the 300 had 157 teeth, I think it will work. There is also a difference with the starter hole diameter on the bell housing dust shield. The thin plate between the motor and bell. |
The flywheel i have is smaller than the original 6 cylinders by like 3/4"
So im sure the starter wont grab. Im wondering what starter would work in the smallblock bellhousing that would grab the 157 tooth 10.5 flywheel? |
The starter's are the same, they are just clocked a little bit closer to the flywheel. If you have both bell housing's you can see the difference in the area where the starter bolt's to.
JFlom77
After read your last post I was thinking same as Big. Block said. All the starters I've seen always have the same size drive gear. It not like I've seen large starter gears and smaller ones. The started must just be farther from the center of the crank for a larger ring gear. Which means the ring gear has to be matched up with the right bell housing. |
