removal of oil fill question
Can you remove the oil fill without removing the injection pump?
it just bolts on to the front cover. The ip has separate bolts are behind the oil fill / cover.
Be careful when you put the bolts back not to strip them out. They don't require too much torque. I did that... But the rtv holds the bolt in. |
Ok thank you very much my truck is leaking oil like sive from around there. I didn't want to start to take it off then realize I would have toremove the ip to do so since I really don't feel like doing that right now.
The "oil fill" does not just unbolt, if you are talking about what I think you are. Look at the sticky about timing at the top of the page.
This one: https://www.ford-trucks.com/forums/1...alignment.html |
bashby, some of the oil fills do unbolt off the front of the cam gear cover/IP mount in the location of the IP Gear bolt access cover.
Some are cast as part of the gear cover and use a flat plat for the IP Gear bolt access cover. I am looking for a bolt on to put on my custom gear cover. -Enjoy fh : )_~ |
Mine is an 85 if that tells you how the cam gear cover is
Originally Posted by 79sparky
(Post 12831858)
Yeah its all one piece has two bolts ontop and two ubder the ip
Sounds more like you want to remove the IP Gear cover ...
If that's the case. WARNING Incorrect removal will cause you great headaches. Injection Pump Gear Cover Re-Seal Basics.
-Enjoy fh : )_~ |
Oh boy between return lines and that soundslike I'm going to be busy Saturday thanks a lot yhough for the very informative post its gonna really hell a lot.
Is cylinder 1 on thd passenger side of the engine?
(Post 12834637)
I want to say its labeled on the intake, but maybe I'm thinking of the firing order. |
I figured it was being a ford but I didn't knowhow international does it andi wouldn't know what would be on the intakd since I've never seen the stock intake lol
Each cylinder is numbered on the intake runner to that cylinder, the firing order (12734568) is also on the intake.
Front of truck. 2 - 1 4 - 3 6 - 5 8 - 7 Drivers Seat! The biggest worry is knocking the gear off when pulling the cover, however the gear is pretty stable setting there and as long as one is aware it's no biggie! It will roll a little to one side or the other, that's ok, just mark it where it's at or re-center it and mark it. Just don't disengage the teeth until marked! -Enjoy fh : )_~ |
Alrighty good to know and thanks for all the help
