dodge aluminum wheels?
Does anyone know if 8 lug wheels from a dodge 3500 pickup will fit on an 04 e250? I think they are the same bolt pattern, but I am unsure of the center hole diameter. Thanks in advance!
E250 center bore is 124.9 while the Dodge is 122.5. The bolt pattern and stud size is the same.
Thanks for the quick reply...I guess those wheels won't fit. Too bad, they were a good deal.
You could have a machine shop bore them out larger, might be worth checking out if they're nice wheels.
3500 Dodge is a one ton dually, DRW wheels won't fit on a SRW van.
I picked up some aluminum wheels that were on a Chevy truck. Same bolt pattern, and worked great so far. No fitment issues, and the offset was the same. They were not OEM though.
Working fine on my 2001 E350SD. |
Thanks for the replies...maybe I will look for a set of Chevy wheels. The Ford wheels are just too expensive.
many aftermarket wheels have the ford-size center hole to make them more universal, as ford had the largest hole of any of them. i believe stock chevy wheels have a smaller center hole than fords
