Strange hesitation from 1st to 2nd gear (only happened once).
I bought my 2011 F250 FX4 about 2 months ago. A little about the truck: 6.2 liter gas. XL FX4. Manual 4x4. 6 speed auto. Supercab. Long bed. 42,000 miles. (1,000 of them mine.)
Until yesterday, the truck has performed absolutely flawlessly under all conditions. Then, randomly, I had what felt like a "missed shift" as I was leaving my dog's veteranarian yesterday. I pulled out onto the highway and as the truck attempted to shift into second gear, it didn't "catch" second. The gas just revved up and I had to take my foot off the gas pedal and put it back down to get second gear to engage. Most of my driving is stop and go around town and this has only happened once in probably well over a thousand stop and go situations. Should I be worried or was it just a fluke? Also, FWIW, I did plenty of stop and go driving today without a single problem. |
I need to learn to title my threads better. Someone else must have experienced this before?
1 Attachment(s)
It's a strange anomaly that effects some trucks. I attached a TSB for the '11 6.2 which may or may not have been done on your truck. Some guys had it done and it corrected it, some had it done and it didn't.
I used to be able to make mine do the missed shift from 2-3 after sitting a while. I had the tsb done and it's done it maybe 2 or 3 times in almost 2 years, and it was very minimal/quick when it happened. |
Thanks a lot man. I will take this to my local dealer. What sucks is that I bought the truck 3 hours away. Hopefully, the local dealer will work with me.
There's no reason why they shouldn't work with you, it'd be covered by your warranty (if you're still under the mileage).
If it's only happened once since you've owned it, it may not even be worth taking it in, up to you though, post back what they say if you end up taking it in. |
Originally Posted by 2000silverbullet
(Post 12809785)
Just an update. It's been ten days, I've towed an 8,000 lb. trailer, and no further problems. I'm gonna say it was a fluke and forget about it.
my new truck has done this several times also, today in fact--
its like it hits nuetral for a moment or two between gears, i think its way to intermitten to take it in now |
Ya know, my 12 Fusion does this (yes I know it's totally different) but its exactly the same randomly when the trans is still cold. Hmm
OK, this problem has come back with a vengeance. It happened once or twice over the last few months, then it started happening every few days this month. Truck will be going to a dealership soon to try to figure this problem out. Has anyone had this issue and successfully had it fixed? Not looking forward to hearing a service tech tell me "We couldn't duplicate the problem."
Yes, print out the TSB and take it with you to the dealer.
Originally Posted by Diabolical!
(Post 13438929)
Have you been to the dealership yet to have this addressed? Let me know how things went; if you need any additional assistance, give me a shout. Crystal |
Originally Posted by FordService
(Post 13450545)
Hi Diabolical!,
My dealer always blamed the "learning trans" when I complain of hiccups.
(Post 13504475)
Sorry, haven't had a chance to get online in a while. Thanks for addressing this. I will be taking the truck in at the end of the month. (I just can't afford to be without it before then.) My dealership is typically pretty helpful, but if I have any problems I'll be sure to get back with you.
Crystal |
