Carr Super Hoop Steps. Good quality or not?
I have a 1988 F350, which is lifted 7 inches on 38s so it needs some steps.:-X04 I was looking at the Carr Super Hoop Steps, but was not sure how good their quality was. I have heard that they were pretty good, but some people thought they could be a little stronger and needed some heavier duty parts. So they bought extra parts to replace the weak ones.
So I was wondering if you guys thought that the steps are strong enough bought new, or if you guys think they need to be beefed up a little. And if they do what parts need to be replaced. I was looking at the polished version and was wondering how the finished lasted. I was also wondering what is a good place to buy them from. So feel free to share your guys opinions/expereriences with the steps. Thanks for any help in advance.:-X22 |
Originally Posted by RedDevil460
(Post 12787378)
Thanks for your response. The finish isn't a huge deal, was just wondering, but I will still try to keep them as good looking as I can. Yeah I'm a pretty big guy too so they need to be pretty solid. So do they feel solid to you or do they feel weak, and do you know if the previous owner changed any of the original parts to them?:-X22
No parts changed. Biggest thing to worry about is rust on the rocker panels. You get that and you're screwed. Then the metal weakens and those nice steps are gonna break the rockers off the cab
So what are they mounted to the frame or the rocker panel or something else?:-huh
(Post 12788212)
Ok. So is that how regualar nerf bars and running boards are mounted too? Becuase if they are then I would feel more comfortable about the step being mounted the same way as other things that I know are pretty solid.
(Post 12788236)
Ok. Thanks a lot.:D. I just want to make sure that I would be getting something sturdy for my truck and that it will last.
(Post 12788306)
PM sent.:D
(Post 12788324)
PM sent.:D
Yup I got em. Thanks a lot. They cleared things up a little bit. They do look to be mounted pretty sturdy to the truck. Do they come down pretty far to make it easier to get into. I know you can adjust them, but either way I will definitely be getting these for my truck. Again, thanks a lot for your help.:-X22
I just took another look at the pics and noticed that you have an older style, because the new have an adjustable mounting system so you can adjust the height and angle. Which is pretty cool. Just pointing it out.:-X22
(Post 12788377)
