2006 freestyle no heat passenger seat
hi guys 2006 ford freestyle and there is no heat on passenger seat the light on the dash lights up for a second when pressed but then goes out any help would be great thank you
Are you talking about heated seats ? Or dual zone heat ? More info please .
heated seats
the passenger side heated seat isnt working
Ck fuses first , but sounds like you need someone with the proper diagnostics scan tool . Maybe someone else will jump in with better info for you , Good luck !
The seat element is out. You can repair yourself or take it to a shop depending how mechanical you are. They sell the replacement elements on Rock Auto reasonably priced. They sell a upper and a lower so you need to know which is out because they are wired together (if one goes, they both don't work).
