1997 Ford F250 Heavy Duty Diesel, I NEED A 4 DOOR!!!
Call or Text 478-808-7889 for any additional pics or info
***DO NOT OFFER ME JUNK. I AM IN NEED OF A 4 DOOR TRUCK BUT I WILL NOT TAKE JUST ANY OLD TRUCK. I HAVE A BAGGED & BODYDROPPED SHOW VEHICLE I WILL STILL HAVE TO HAUL OR THE SHOW TRUCK COULD QUITE POSSIBLY BE THROWN IN ON A TRADE FOR THE RIGHT TRUCK. I HAVE PICS OF IT IF THE DEAL IS RIGHT. EXTENDED CAB TRUCKS ARE OK AS LONG AS THE BACK DOORS OPEN. I PREFER DIESEL BUT WOULD CONSIDER THE RIGHT GAS TRUCK IN GOOD ENOUGH CONDITION WITH LOW MILES. KEEP IN MIND, EVEN THOUGH MY TRUCK HAS HIGH MILES, THESE ENGINES ARE ALREADY BULLETPROOF AND WILL RUN FOR A MILLION MILES OR MORE WHEN THEY'RE WELL MAINTAINED LIKE THIS ONE IS & HAS BEEN. THIS TRUCK DOESN'T LEAK ANY FLUIDS & HAS NO BLACK OIL WHATSOEVER INSIDE OF IT.*** 1997 Ford F250 Heavy Duty XLT Extended Cab 2WD $9,000 or best REASONABLE offer or trade -345K miles & counting, this truck is driven everyday -XLT Model, all options, no leather, PW, PL, CC, Tilt wheel -Built transmission w/billet triple disc converter, shift kit, & larger valve body, 3 year/ 100k mile transferable warranty (Installed 08/12) -Upgraded transmission cooler (Installed 08/12) -New factory intake hose from turbo & 6637 filter (Installed 12/12) -3 in. Diamond Eye downpipe, 4in. Diamond Eye exhaust into 8in. Pypes tip (Installed 03/12) -A-Pillar gauge pod w/ 7 color GlowShift gauges (Boost, Exh. Temp., & Trans. Temp.) (Installed 03/12) -Edge CTS Touchscreen Tuner running in Level 3 Extreme Tune (best fuel mileage) (Installed 08/12) -8K HID headlight conversion, Smoked tail lights -Spray-in Line-X bedliner with gooseneck hide-a-ball hitch -Below-the-bedrails black diamond plate toolbox -Tekonsha electronic trailer brake controller -JVC CD/MP3 player w/ front face USB & Aux In., detachable face & remote, 5 volt sub pre-out -Pioneer 3 way 6.5's in doors, JL Audio 3 way 5x7's in the rear -Almani 1800 watt mono block amp, 1.5 Farad capacitor -2 Rockford Fosgate Punch HX2 12's in a tuned port box -5% window tint on doors, 2.5% window tint on ext. cab & rear window -Husky Liner brand tan fitted floormats -265/75/16 Falken Wildpeak A/T's (Installed 12/12) There is 1 crack in the passenger side of the dash that's smaller than a dime, 1 crack in the windshield on the drivers side in an L-shape that's less than 8in. long & covered mostly by the programmer screen & gauges, and 1 small tear in the headliner less than 1in. No rips, tears, or stains in the seats nor carpet REBUILT FRONT END WITH UPPER & LOWER BALL JOINTS & FRONT END ALIGNMENT (11/21/11) FRONT BRAKES W/ CERAMIC PADS & NEW ROTORS (07/11) NEW ALLIANT POWER IPR VALVE (09/12) I BOUGHT THE TRUCK IN 08 WITH 236K ON IT. SINCE THEN I'VE REPLACED THE CPS (FACTORY RECALL), CRUISE CONTROL MODULE (FACTORY RECALL), BOTH BATTERIES (01/2011), REAR ABS SENSOR, ALTERNATOR, FUEL PUMP, BLOWER MOTOR, BLOWER MOTOR RESISTOR, WATER PUMP, IDLER PULLEY, SERPENTINE BELT, & A POWER STEERING HOSE. OIL STAYS LIGHT BROWN EVEN @ TIME OF OIL CHANGE, NO BLACK OIL IN THIS TRUCK. OIL CHANGED EVERY 5K WITH ROTELLA 15W/40, 2QT. MOBIL 1 FILTER, & 1 QUART OF POLYDYN TX-7 ENGINE TREATMENT. Click this link to watch a walk around video of the truck on YouTube: Click this link to see more pictures: https://www.facebook.com/media/set/?...7064297&type=3 Thanks for looking. More pictures available upon request. Serious offers ONLY! LOOKING FOR ANOTHER DIESEL, SRW OR DRW, MUST BE 4 DOOR ***PREFER A DIESEL, WILL CONSIDER THE RIGHT GAS*** |
Additional pics of the truck ---> 1997 Ford F250 Heavy Duty Diesel - $9000 (Centerville, Ga.)
Originally Posted by freaks97
(Post 12741003)
sounds like a good running truck. |
