Carburater enrichment valve question
Hey guys,
I have an engine out of a 1975 ford maverick. Its a 302 and came with a two barrel carb. I went to rebuild the carb and bought a kit form the local auto parts store. I figured everything out except for the enrichment valve. I was confused when i went to swap it because the one that came in the kit was an 1/8 inch shorter than the one that came out of the carburater. It also looked slightly different. I put it in and assembled everything and am wondering if it will make a difference. I have a picture for reference but I cant figure out how to attach it. Anyone have any ideas? Thanks, Nathan |
The only thing I can contribute here is to tell you the valve you are speaking of is called the "power valve". That term may help you if you are doing internet searches on the subject to get more info.
Enrichment valve is another word for power valve. As long as the valve threaded correctly and was able to seat, and this was indeed the correct rebuild kit, it should be fine. Many parts look different between kits - this goes for needles, seats, and many other items. If it runs correctly at open throttle, then there is no need to worry about it.
Originally Posted by cyris426
(Post 12719814)
I have an engine out of a 1975 ford maverick. It's a 302 and came with a two barrel carb. I went to rebuild the carb and bought a kit form the local auto parts store.
I figured everything out except for the enrichment valve. I was confused when I went to swap it because the one that came in the kit was an 1/8 inch shorter than the one that came out of the carbureter. It also looked slightly different. I put it in and assembled everything and am wondering if it will make a difference. I have a picture for reference but I cant figure out how to attach it. Anyone have any ideas? D5DZ-9A565-A .. Fuel Enrichment (Power) Valve ~ Marked with daub of brown paint (Motorcraft CE-122). If you aren't aware of where the car was sold new, there are SEVEN different 49 state power valves (same used in: 1975 Granada/Monarch/Mustang II 302/C4, excludes Califonia). These valves are marked w/a daub of paint, so if concerned, look at the original, see what color it is. |
Could we see some pictures? Here is how.
Quote: Originally Posted by 76f350spercamprspeal Welcome to FTE, Best Damn Forum EVER! ------------------------ Here's How to Post Pictures: 1. Login to FTE. 2.Click User CP (In the Top Left Hand Corner) 3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That. 4.Then, Click Add Album, Enter a title, and description, if ya want to. 5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time) 5. Click Upload. 6. Add a description to the individual pictures, then click save. 7. Add more files if ya want. 8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG]) Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post. You can add up to 30 Images in one FTE Post. If, Ya need any help, Don't hesitate to ask. Quote: Originally Posted by old_dan You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album. It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available). Quote: Originally Posted By Jolly Roger Joe Welcome to FTE! Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE. While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this: The best photos and videos | Photobucket Copy that highlighted info (right click / copy). When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens). Your pic will be placed in the post. Hope that helps. Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html |
