Tony Wildman Smoke Tune ???
I have a 1995 Ford Powerstroke, Automatic and completely stock. I am wanting to get a Chip or programmer for it and I want it to add power and smoke alot, I heard of the Tony Wildman, and does he still have the smoke tune ? and does it work ? Please dont comment saying how bad it is for diesel to smoke or why would I want it to smoke
Walmart bag mod much more effective and a lot cheaper
Originally Posted by 96ford250
(Post 12719345)
As for the OP go for it, you will look like a goon for a few months then you will realize its dumb and won't want the smoke tune anymore and wish you had spent your money on a good econo or tow tune. Diesel Rod |
Welcome to the forum, glad to have you........... You will be hard pressed to get much smoke from your stock engine even with a performance tune. I'm not sure about a smoke tune, I guess it's possible, low rpm full throttle no boost.
My truck will blow a ton of smoke with the stage one Swamps, but I'm older and I have gotten to where I hate to see it do it. One reason is because or gov. will put a stop to our tuning if it gets out of hand. And it's just not good to begin with. Maybe someone will post what your looking for.............. good luck |
Ever sense the EPA notified the chip tuners about the fines involved, they are charging and extra 100 bucks for the smoke tune, ya go straight to jail if you get caught smokin in CA :-X22
Originally Posted by Djones2121
(Post 12719310)
Please dont comment saying...why would I want it to smoke
Thanks everyone for there input, Im going to just order some Tony Wildman Tunes and probaly wont get the smoke tune
I must be getting old...i want the drivethrough quiet tune...that would be great!
With stock injectors you will not get the "Black smoke" that you want.
Now before you order your chip, You said your truck is stock, you should do some things to help your chip work better like the 6637 air intake and a 3inch downpipe. Also i would suggest you get gauges EGT and trans at least to monitor your temps while your using your tune.
But in the long run all black smoke is unburnt fuel. and in ohio diesels at 4 bucks. sooo think about it. |
Blowin smoke is :-lamesign, you must be around 18 years old? And get ready, cause cities and states are starting to implement laws on this. There are some Texas cities that give you a 10k fine right off the bat; no warning. They are not stupid, they know diesels don't NORMALLY smoke like a refinery that is on fire.
Originally Posted by 444dieselrod
(Post 12719422)
Actually that doesn't work, the Map wont see boost and you get no fuel...
Diesel Rod |
