Dry Vinyl Tape
Does anyone know of a supplier for dry vinyl tape in Australia?
I can get it from the manufacturer in the states but only in box lots (20mm tape, 160 x 30m rolls in a box). I really don't need 160 rolls. 2 - 3 would probably do what I need. |
fleabay perhaps?
Tried there.
Only from the states. |
What's it used for?
Maybe you can become the Aussie supplier care of 1 bulk order from the US and selling off the surplus via ozzy-fleabay. I tend to use the rubber self-bonding 'dry' tape for lots of odd sealing jobs on the truck and around the house. |
Originally Posted by SSSimon
(Post 12715629)
What's it used for?
(Post 12715629)
(Post 12715629)
I've got silicone rescue tape but given that it's about $1 a meter it's way too expensive to use for wiring loom. |
Originally Posted by 4x4falcon
(Post 12715794)
Source for this? Is it good for high temp.
Similar pricing to rescue tape. The dry vinyl is about 5c per meter and it's what Ford and other manufacturers use. |
I got 2 rolls through a TV ariel installer. He said they buy it by the box load and use a roll of tape per install.
Available here:
Self Amalgamating Tape That's about the cheapest I've seen it. I bought mine in Kmart Karratha when they had a sale on. $10 per 5m roll. |
Only suggestion I have is to use the self-amalgamating tape but NOT to form a continous loom. Just bind the wires at every junction then every 10cm or so, then encase in the black plastic split loom.
