100hp Injectors
hi im looking to install 100hp injectors in my 2003 ford f250 7.3l and was wondering if this is a bad idea or not? i have a ts proformance 6 position chip with stock, lope, 80hp daily driver, 100hp race and 120 race. also i have a S&B auto cold air intake, with an exhaust with a 3in down pipe into 4in then into 6in stacks... i heard if you get to much HP it is bad for the connecting rods? is this true or can i get away with 100HP injectors??
You have pmr rods, so yes they are weaker than forged. What size injectors are you talking about? When you say "100 hp" injectors nobody knows what your talking about.
ok, they are the 100hp nozzles...here is the link for them so you can see what im looking to get...
8 New Alliant Injectors w 100HP Nozzles Ford Powerstroke 7 3L Diesel Truck 99 03 | eBay |
The price is way to high. And it sounds like all they are doing is honing the nozzle and not doing anything to the injector itself, which won't get you any where close to 100hp
You can get stage 3 hybrid injectors from Riff Raff diesel for $1895 |
the price is with a 1200$ core charge so subtract 1200 hundred from that. but what is the site i can find them on? i need to get them and i dont really want to go back to stock so if i can get away with any aftermarket without causing any damage to my motor i want to get them...
Check again...the $1200 core charge is above and beyond the price of the injectors.
Riff-Raff is a site sponsor. Look on top of this page.... |
there is Riffraff, Full Force, Beans, Farmers......Contact Clay at Riffraff or Matt @ Full Force (just google them)...Keep in mind, you will probally have to sent the chip back for updated tunes for your injectors...and yess, the link is way to high and siund like split shots (factory injectors)
Originally Posted by Yingling256
(Post 12670243)
Riffraff Diesel Performance Parts: Diesel fuel injectors | Ford Powerstroke fuel injectors | 7.3L Fuel Injector - Full Force Diesel / Casserly |
would i have to send the chip back to kt performance or send it where i would get the injectors?
(Post 12670374)
KT performance, they shouldn't charge you anything. Most tuners have free reburns |
okay, thanks guys you helped me out alot! and saved me a bunch of money!!!!
Take a look at Swamps diesel. They are the ONLY company that's builds their own injectors and also does their own tuning. I like the idea of no finger pointing between the injector suplyer and the tuning company. Swamps may not be the cheapest but, They have the best warranty you will find.
if i put these injectors on will i have to do any upgrades such as fast fuel, Bigger fuel pump or anything like that?
Before you enter your card number into a field for ordereing, consider this:
I ordered the Swamps 200/30 injectors (stage 2 aprox 450 horse) and I have a 38R turbo and I was told I won't need anything else other than my regulated return. You may be better off with the 175/146 injectors (stage 1) which I believe will get you a bit under 400 horse if I remember correctly. There are also 160/80 that many people like. So many choices.
