speedometer cable removal? 78 ford bronco
Hello all,
I am trying to remove my cluster from the dash of my bronco. The speed cable is attached by a white clip. I can't get it disconected from the cluster and I don't want to break it. Can someone tell me how to disconect the speed cable from the back of the cluster. I am sure it has something to do with the white clip but im just not sure what to do with it. I would really appreciate some help. thnx, Duke |
It's easy, (yea right) there is a plastic tab you can't see as it's to close to the dash. you just need to squeeze it in about the middle, them it will slide right out. Just keep squeezing in different places. It should slide out very easily, you won't need to force it, however they are easily broken.
thank you so much, I will give it a try. thnx, duke
If you go under search (TYPE speedometer removal, there is a picture)
<TABLE id=ncode_imageresizer_warning_1 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20>https://www.ford-trucks.com/forums/i.../wol_error.gif</TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE>http://i1196.photobucket.com/albums/...2/c16242d2.jpg
thanks again! i got it figured out
