223/240 swap
Hello forum, hey, can I swap a 223 in place of my 240 which is bolted to a 4 spd T-98? The 223 is a 61 year, and the 240 is a 66 year. Merry Christmas to all
If I needed to replace a worn out 240, I would seriously consider a 300 cu in six. I think it's a direct replacement and there always seems to be one or two on CL. Not sure about the 223 being a bolt up. I guess it's just me, but I've always wanted a 300 six. My first truck ever was a 65 f 100 I bought in 1971 with a 240. I thought I was the king of the world!....
As Gary said, a 300 would go in there easier. A 223 would take a few extra parts but if you already have all you need, throw it in there. i am a big fan of the 223!
If you have a 240, why not get a 300 to build with the 240 head? My understanding is that gives you a higher compression ratio on a budget. That and some 1.6 rockers for the mild cam effect and it's an engine that goes good and will last a long time. Keep in mind this is just what I've gleaned from the interwebz
Originally Posted by 99hosss
(Post 12628665)
Motor mounts may be different as well. I'm not sure, but it is possible the 223 uses a front mount and the side mounts are off the bell. You can check that easily enough. The 240/300 uses side mounts. IF you want to swap, go with the 300 and a Mazda or ZF 5 speed. (serving suggestion) Col. Flashman has a 300 in an older truck, if you are still interested in the project, he can be looked up and consulted. This isn't that big a change, but it's not quick turn of the wrench. |
Thanks to all for the info, I just finished my 66, had it ready to drive in our local C-mas parade, and the week of the parade the crank spun a bearing. I have this complete 223 in the garage, just was hoping it would fit in for the winter- The 300 idea sounds like the way to go, Happy holidays to all
FTE member Col Flashman swapped a 300 I-6 into his 1958 Mercury M100 that originally had a 223. Suggest you contact him for details.
He also swapped in Toyota P/S. |
